Mysterious Dark Puddle
Old Nov 28, 2010 | 09:35 PM
oneloudskunk's Avatar
Question Mysterious Dark Puddle
I just went outside and moved my car for the night only to discover a dark puddle where it was sitting. The puddle is located below where the rear-center of the car would be just ahead of the rear wheels. I took a whiff of the puddle, and it definitely didn't smell like gas but had a more solvent-like smell. I looked under the car and it seems to be coming from above the fuel tank; or at least what looks like the fuel tank in the dark. Anyone experience this before?
Old Nov 29, 2010 | 05:44 AM
Brake fluid seems likely. Check your brake fluid level.
Old Nov 29, 2010 | 08:55 AM
Not brake fluid. Brakes are good and hard.
Old Nov 29, 2010 | 03:04 PM
Not much else back there besides fuel & brake fluid. Did you check the fluid level in the brake master cylinder? (Brake pedal going mushy happens after it ALL leaks out)
Old Nov 29, 2010 | 05:33 PM
Drove the thing all the way to work and back today. Brakes are fine. Crawled underneath when I got home and discovered that it appears to be coming from the extremely rusty spot in the front of the fuel tank.
Has anyone ever attempted this procedure before in their driveway? I'm no spring chicken when it comes to automotive repairs, but dropping the rear subframe without a lift just sounds like an uber pain. What would I expect to pay for such a procedure?
Old Nov 29, 2010 | 07:06 PM
It's not the worst I've tackled. I used front ramps and rear Jackstands to elevate. You may have a leaking tank if corrosion is bad.
rics06
Jun 12, 2013 07:11 AM
rics06
Jun 4, 2013 04:44 PM
pr1286
Aug 22, 2010 01:22 PM
Apr 14, 2009 08:12 PM
maro
Aug 16, 2008 12:09 PM
