Help, 1990 Accord won't start!
Old Feb 11, 2009 | 07:42 PM
  #21
jmalek's Avatar
I put in a new coil tonight and it fired right up! I can't thank both of you enough for all the expert help, I don't think I would have figured it out without you.
I wonder if the code 15 was still in the ECU memory from before I replaced the igniter, since I didn't reset it afterwards? In any event, it works now, so thanks again.
Old Feb 12, 2009 | 06:37 AM
  #22
Thanks for letting us know.
Old Mar 24, 2010 | 04:17 PM
  #23
bourguet's Avatar
Default help
my 1990 honda accord wont start the smorning i turned it on to warm it up and as i was doing so it shut off and wouldnt turn back on it wont even turn over i know its the not the batterie cause i just bought it any one have any advise
Old Mar 24, 2010 | 04:28 PM
  #24
bourguet's Avatar
sounds like youre good with cars would you mind giving me some advise my 11990 handa accord wont start it was running fine yesterday and then the smornig i went to warm it up and it turned on and then it just died and wont start agin it wont even turn over i just bought a new batterie i know it cant be that but id really aprceate it if you could help me i dont know nothing about cars
Old Mar 24, 2010 | 04:32 PM
  #25
Jmalek's cranks. Yours doesn't (right?) So that makes it a different problem.
Check for dirty/corroded/loose connections on BOTH ends of the battery cables.
Old Mar 25, 2010 | 03:10 AM
  #26
NEIL's Avatar
Default my 1992 accord lx is having the same problems as jmalek.
i pretty much tried everything that i could for my ignition change the plug wires,plugs,distributor and the main relay. i check all the fuses the volts going to the ignitor. i still have no spark at all. the mechanic told me it maybe the crank position sensor is bad or maybe it could be my ECU. I need an advise should i just pay for a new ECU or is there something else that i need to check.
Old Mar 25, 2010 | 04:10 AM
  #27
When you try to start the car, does the starter motor spin the engine?
Old Mar 25, 2010 | 08:49 AM
  #28
bourguet's Avatar
hey thanks for the help i figured it out my ignition fuse was blown thanks agin
Old Mar 25, 2010 | 02:53 PM
  #29
NEIL's Avatar
Default yap
yap its really the same thing as jmalek crank no spark. if your crank sensor is bad would it caused it not to have spark. the tech told me that iT could be a bad ECU. how do i checked my is ECU IF ITS GOOD OR BAD.
LordDCLXVI
Aug 1, 2011 07:04 AM
ejcr032
Mar 15, 2011 04:35 PM
chingwms06
Aug 30, 2009 07:26 AM
1990honda
May 7, 2009 11:49 PM
PedroG
Aug 6, 2006 03:25 PM
