HELP! 2004 Honda Accord Hissing sound
Old Feb 22, 2012 | 12:30 PM
tlmmlt's Avatar
Default HELP! 2004 Honda Accord Hissing sound
My 2004 Honda Accord is making a sound that sounds like hissing. The first thing I thought of was air being let out of a tire. You can hear it off and on while car is moving but much louder when breaks are applied. Not at all while at a complete stop. I need to drive about 30 miles home like this, I hope it is ok to drive?!?!?
Old Feb 22, 2012 | 12:32 PM
May be your brakes pads are worn, and the sound is from the wear indicator.
https://www.hondaaccordforum.com/for...ont-end-17829/
Old Feb 22, 2012 | 12:40 PM
tlmmlt's Avatar
So break pads will make the sound even though the breaks aren't applied?
Old Feb 22, 2012 | 12:44 PM
Yes. Almost for sure it will be your brake pads are worn, the inner pad(s).
Old Feb 22, 2012 | 12:46 PM
tlmmlt's Avatar
Do you think they will be ok to drive 30 miles to get home? (I am a female of course)
Old Feb 22, 2012 | 12:57 PM
Definitely you can drive it for 30 miles and more. You still have some margin to drive it for a little while. The wear indicators are on the inner pads only; but, they are softer metal than the brake rotor, so although it sounds bad, for now, it's not doing any really damage. If you continued driving it for too long like that, then damage will occur and you will need to replace the rotors (rotors are more expensive than the pads). But, depending on your driving style, you probably can go a week or so; but, the sound will get progressively louder.
Also, when getting the brake pads changed, you do not necessarily need the rotors "turned" (e.g., machined, removing some of the rotor surface), unless you have shaking (shuddering) when applying the brakes at a higher speed, say for example, a sudden stop from 60 mph. Changing just the brake pads without turning the rotors will save you some money.
Old Feb 22, 2012 | 12:59 PM
tlmmlt's Avatar
Thank you so much. I will get it home and not drive until it is fixed. Thanks again!!
Old Feb 22, 2012 | 01:06 PM
No problem. But, you can still drive it a little more than just getting home.
Old Feb 22, 2012 | 01:13 PM
tlmmlt's Avatar
Ha might be true for most but not a nervous nellie like me!! thanks
accordjk
Jun 27, 2014 11:08 PM
Cattywampus
May 12, 2011 10:53 AM
hondilly
Dec 26, 2008 12:23 PM
sbutler
Apr 22, 2008 10:57 AM
spliffy
May 6, 2007 04:25 PM
