HELP! 2006 accord v6 check engine light blinks 5 times then goes away
Old Oct 12, 2015 | 12:50 AM
Accordlove's Avatar
Default HELP! 2006 accord v6 check engine light blinks 5 times then goes away
So a buddy of mine cracked his oil pan and replaced it but now the car wont start. We tried connecting bt obd scanner but it wouldnt connect.
Old Oct 12, 2015 | 06:13 AM
Turtlehead's Avatar
A couple of things... First was that scanner every used on that car? Some older scanners may not be able to link or it was not securely attached. Second, the cars does not start does not tell us enough, is it cranking but not starting or does it do nothing.
Typically a check engine light that flashes and goes out it a system readiness fault. Depending on where the oil pan was struck you should be checking the crank position sensor and wiring and all wiring under the car that may have been damaged. If the engine does not crank, set the e-brake, turn the key to the on position, push the brake and shift the car to neutral. Then using a 19mm socket on the crank pulley see if the engine turns. If it does turn and all wiring under the car has been inspected it may be the immolizer system or likely some other electrical issue.
Please provide more information.
Old Oct 12, 2015 | 09:25 AM
Accordlove's Avatar
Default Thank you turtlehead for replying so urgently
I have never used my scanner on his vehicle but have used it on my 6th gen accord and a 2011 corrolla. When he attempts to start it cranks but it sounds slow.
Non Quixote
May 19, 2021 01:22 AM
bigdawg74
Aug 16, 2010 11:29 AM
rummermail
Aug 2, 2010 04:03 PM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
