Help with 2019 Ridgeline
Old May 8, 2022 | 11:41 AM
Steamed's Avatar
Default Help with 2019 Ridgeline
New user and having difficulty finding how/where to ask a question.
have a 2019 Honda ridgeline with a emission problem
Primary]: DIAG1 :Found leak at fuel filler neck, the inner valve is broken and no longer sealing. P0456 P0456 small evap leak C/S: EMISSIONS LIGHT ON. CUSTOMER HAD ISSUE ADDRESSED AT HONDA DEALERSHIP IN ARIZONA FOUND THEY FOUND EVAP SYSTEM LARGE LEAK CODE.CLEARED THE CODE AND PERFORM EVAP FUNCTION TEST AND IT PASSED
so Two different dealerships and two different opinions, dealer two says about a grand to fix. I can stick my finger and move this flapper valve and seems solid, no gas smell. Looking for a different answer, thanks Dennis
Old May 8, 2022 | 01:35 PM
What code(s) you are getting? They start with the letter P and have four numbers, like P1234.
The descriptions above indicate an evap leak. The leak can be anywhere in the evap system. It could be a bad seal or possibly an evap valve that is not closing properly.
Any chance you have a scanner that can read live data? Better yet, does it have some troubleshooting functionality where you can use the scanner to test the EVAP system?
Old May 8, 2022 | 02:04 PM
Steamed's Avatar
According to diagnosis above code says P0456, on repair estimate they have p455&456( assuming left out zero). No I don’t have a scanner. On repair receipt the two problems this causes is emission warning is always on and might take longer to fuel up. Sure doesn’t seem like a 1000$ problem
Old May 8, 2022 | 02:53 PM
shipo's Avatar
The fix for the issue could be relatively inexpensive, or it could well run well over $1,000; it all depends upon how easy it is to find the leak, where it is, and what parts need to be replaced. Until it is professionally diagnosed, there really is no way to know what it will cost to fix.
Old May 8, 2022 | 03:37 PM
Steamed's Avatar
That’s the rub, two professional opinions from two Honda dealerships. That’s why/how I found this forum , hoping someone else had this same problem
Old May 8, 2022 | 04:44 PM
shipo's Avatar
I think you're missing the point; I had a similar problem on my Accord and the parts and labor to fix it was over $1,400, I also had a similar issue on my TL and the parts and labor were under $100. Unless and until you can find what is leaking, there is no way anybody can tell you what it will cost.
Old May 8, 2022 | 04:59 PM
Steamed's Avatar
Huh Wasn’t asking anyone about a cost, did say I didn’t that it was a 1000 $ problem ( to me anyway ). not sure what point you think I’m missing.
Old May 8, 2022 | 05:11 PM
DTC P0456:Evaporative Emission (EVAP) System Very Small Leak Detected
There was a fuel pump safety recall, you may be able to get Honda to cover the inspection by doing the recall inspection.
The fuel tank is part of the Evaporative Emission (EVAP) System.
https://static.nhtsa.gov/odi/rcl/201...9V053-7809.pdf
Old May 8, 2022 | 06:44 PM
Steamed's Avatar
Thanks for that! Will check into further.
Old May 8, 2022 | 07:42 PM
Also, certain major components should be covered under the Federal Emission Warranty since your vehicle is only a few years old.
Don't get charged and pay for something that may be covered under the Federal Emission Warranty.
Yessy Consuegra
Dec 30, 2013 06:55 PM
LordAccord
Oct 26, 2012 10:27 PM
jfidelh
Dec 1, 2011 01:39 PM
prymerider16
Oct 12, 2010 09:20 PM
dvsccn
Nov 12, 2009 06:45 AM
