help
Old May 29, 2006 | 03:21 PM
specsen
Default help
I need some help guys. A friend of mine has a 97 accord. It seems to drive fine MOST of the time, but her Tach bounces from 0- 4k rpm as she's driving, and then everyonce in a while it will cut out just a bit. Not terribly bad, but it will stall just a little. I don't know much about the car, but she said she did change the spark plugs within the last year. Other than that I know nothing. Any help would be greatly appreciated.
Forgot to add, its a 97 accord EX V6.
Old May 29, 2006 | 03:29 PM
YeuEmMaiMai's Avatar
Default RE: help
test the ignition module. is the car tossing any codes? how does the coil test out?
Old May 30, 2006 | 03:26 AM
deserthonda's Avatar
Default RE: help
ORIGINAL: specsen
do as Yeu adviced.. remove the distr cap and chk all the wires ( 4 ) on the icm ( ignition control module ) ( ignitor ) , make sure they are all tight fit,, the blue wire is the 1 for the tach,,
does the tack jump as car is cutting out ? or does tach jump all the time ?
does chk engine lite come on ?? if so, we need to know the code ( s) that is ( are ) stored ..
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
