Help! 95 Accord Ex Speedometer
Old Jul 10, 2012 | 07:45 AM
671Pete's Avatar
Default Help! 95 Accord Ex Speedometer
My Speedometer sometimes won't work.. Most of the time it stays at 0. any idea what could be wrong.
A second one: My car is Auto Trans. and when I put it in D4 the light (near the speedometer) around it starts blinking. Help??
Old Jul 10, 2012 | 08:28 AM
These could be related.
Suggest getting the codes and lets see what we have from there. Your 95 is OBD-I so all you need to get the codes is a jumper wire/paperclip.
See this for help on how to get them: https://www.hondaaccordforum.com/for...threads-40780/
Once you have the codes let us know what they are and which system (CEL or D4) they came from.
Old Jul 11, 2012 | 08:31 PM
671Pete's Avatar
Not really sure what you meant by getting the codes with a jumper wire and paper clip. Where would the codes show. Sorry, I'm new to the Honda brand... Oh, the problem I described on my post. Will it have any affect of me driving the vehicle?
Thanks!
I looked iN THE DIY sextion, found the thread and was lost when reading what to do.
Old Jul 12, 2012 | 07:58 AM
Once you find the proper connector (explained in that DIY thread about reading codes), you jumper the 2 wires together with a paperclip or some other kind of jumper wire.
With the jumper in place, turn the key ON. The check-engine light will flash the error codes for the engine. The D4 lamp will flash error codes for the auto-transmission.
Old Jul 18, 2012 | 12:05 AM
671Pete's Avatar
Thanks for the feedback! I had the car scanned and the mechanic told me it's the shift sylenoid...and that he recommends the transmission to be overhauled
Old Jul 18, 2012 | 12:08 AM
Do not overhaul the transmission. Is this 4 or 6 cylinders?
Old Jul 18, 2012 | 01:54 AM
671Pete's Avatar
yeah thanks! I got second opinion and I was told not to do an overhaul.
It's a vtech 4 cylinder.. What's my next step? I tried looking in the DIY threads but I"m not sure what to look under..
Old Jul 18, 2012 | 02:23 AM
Locate the blue service check connector and use a small paper clip or wire to jump it. See this:
Blue service connector
Then get the transmission trouble codes and post them, then we will try to help with the codes.
Honda Electronic Transmission Problem- Troubleshoot, Inspection, Repair, Replace.
Old Jul 19, 2012 | 12:05 AM
671Pete's Avatar
Alright, I got 1 long and 7 short.. next?
Old Jul 19, 2012 | 12:11 AM
If that code was from the Check Engine Light, it would be code 17 - Vehicle Speed Sensor. Refer to this link for more info.
VSS - Vehicle Speed Sensor Troubleshoot, Repair, Replace - How To.
