help with 97 accord that engine stopped while driving
Old Jul 24, 2012 | 09:24 PM
  #31
use a 19mm socket on the crank pulley bolt (driver's side of engine block). IF you look behind the driver's tire, you can see a hole in the plastic shield that lines up with the crank bolt. The engine rotates counterclockwise (the engine rotates the same direction as the tires do when in drive).
Do you have a volt meter?
Old Jul 26, 2012 | 07:30 PM
  #32
radoak's Avatar
do u need impact gun or will rachet work on it , and how much do i have to turn it
Old Jul 27, 2012 | 01:26 PM
  #33
Use a wrench, not an impact. You want to AVOID loosening that bolt; you want to turn the crankshaft not loosen the bolt.
Sounds funny, because if you were trying to remove that bolt, it would be really difficult to loosen it. But since you don't want it to loosen, that's probably what will happen.
Turn it counterclockwise maybe 1 or 2 revolutions. You just want to verify that it turns and there's nothing broken inside.
Old Jul 27, 2012 | 03:59 PM
  #34
radoak's Avatar
well tried rachet and inpact , not moving at all
Old Jul 27, 2012 | 04:11 PM
  #35
doctorbee's Avatar
Take the starter out and try turning it again.
Old Jul 27, 2012 | 04:12 PM
  #36
doctorbee's Avatar
Please check oil level as well. I think I know what happened
Old Jul 27, 2012 | 07:40 PM
  #37
radoak's Avatar
oil is good in car , already haad starter out to get it tested , what do u think happened
Old Jul 27, 2012 | 07:58 PM
  #38
doctorbee's Avatar
Sounds like a thrown rod, try rotating the engine the opposite direction and listen for clacking metal in the engine
Old Jul 28, 2012 | 08:18 AM
  #39
Are the spark plugs still in the engine. If so you might remove them to make it easier to rotate the engine.
Old Jul 28, 2012 | 02:51 PM
  #40
radoak's Avatar
ya plugs r still in , took starter out , still can not get engine to crank with inpact or wrench,guess ill try to take plugs out , so if plugs and starter are out , and i can get engine to turn , where does that leave me , do i put plugs and starter back in , and try and start car , or am i looking at doing something else
