Help with Alignment Read Out
Old Mar 25, 2012 | 06:32 PM
lisenod's Avatar
Default Help with Alignment Read Out
Need help reading this alignment. It looks like they just messed with my toes and left everything else the same including my back cambers. Did i get ripped off? I'm already bringing it back because the steering wheel is off center and the car is pulling slightly to the left.
i attached the print out but here is the reading
Before
Left front
Camber .4
Caster 3.0
Toe .09
Right Front
Camber -0.4
Caster 3.0
Toe .12
Front Total Toe .20
Steer Ahead -0.01
Left Rear
Camber -1.5
Toe .15
Right Rear
Camber -1.6
Toe .05
Rear Total Toe .20
Thrust Angel 0.05
After
Left front
Camber .4
Caster 3.0
Toe .01
Right Front
Camber -0.3
Caster 3.0
Toe .01
Front .02
Steer Ahead 0.00
Left Rear
Camber -1.5
Toe .07
Right Rear
Camber -1.6
Toe .08
Rear Total Toe .15
Thrust Angel 0.00
Thanks for the help. Im bringing it back this weekend but i dont know much so would like to be educated
Old Mar 26, 2012 | 06:05 PM
What year is this? Most of the time they also give the "min/max" of the settings.
Old Mar 27, 2012 | 06:22 AM
lisenod's Avatar
Default Thanks
Thanks for the help. Car is an 2006 accord. Min-max for front cambers is .8 to -.8. Front caster 4 to 2.5. And toe is -.8 to .8.
Back camber is -.5 to -1.5. Back toe is 0.0 to .16.
I asked the guy about my cambers that werent moved and he said that some are not adjustable especially in the back. Would this be true on an 06 accord?
Thanks for any help
Old Mar 27, 2012 | 08:37 PM
A good alignment shop will solve this.....not good with the '06 but there are "aftermarket" shims that can be installed to correct this.....
Bottom line, if they can not get the car "within" spec then they should tell you why or give you options to get it "to spec"....and the "wheel being off-center"....well, that should answer how much of your business they get going forward, unless they "make it right".
Old Mar 28, 2012 | 06:09 AM
lisenod's Avatar
Thank you for he help. Really appreciate it.
USEDBLACKSTAR
Sep 12, 2012 10:02 PM
bigdawg74
Oct 27, 2010 08:17 AM
famouzevo
Jul 17, 2009 12:54 AM
Jan 20, 2009 03:23 PM
deserthonda
Feb 7, 2007 03:18 AM
