Help anyone with a 99 honda accord 4 cyl. v tec
Old Apr 10, 2011 | 02:23 PM
dannyh86's Avatar
Default Help anyone with a 99 honda accord 4 cyl. v tec
Hi, this is my first post and I need someone's help. I was replacing my starter yesterday cause it went bad and I found a little hose that I couldn't find where it goes. So could someone do me the favor of checking their car to see where it goes. I have a 1999 accord, 4 cylinders, v tec, automatic transmission and the hose is connected to a little tube under the motor mount next to the battery. I can't see the tube where the hose is connected but I can feel it. The hose is exactly under the motor mount so if someone can check their car I will greatly appreciate it. Thanks
Old Apr 10, 2011 | 02:55 PM
Got any pic's? Or where does the "other" end connect to. I've got a 95 (one gen off), went out and looked and can't really tell what hose you might be talking about.
Old Apr 10, 2011 | 08:38 PM
Usually honda vacuum hoses have a unique number printed on the outside of the hose. If you look at the vacuum hose sticker under the hood, you should be able to figure out what the hose connects.
Old Apr 11, 2011 | 03:05 AM
dannyh86's Avatar
I will try to get pictures tomorrow. I don't think it's a vacuum hose but not sure. The hose is in the passenger side under the motor mount that is behind the battery. I know one end is connected to a nipple or tube that is under the motor mount but the other end is loose. Can anybody help??
Old Apr 11, 2011 | 08:05 AM
How about the transmission breather vent hose (#7 in the picture below). It's a vent - not supposed to be connected.
Old Apr 11, 2011 | 07:03 PM
dannyh86's Avatar
I don't know it could be. Is it located right under the motor mount? Anyone with the same engine thatcan help out???
Old Apr 12, 2011 | 08:42 AM
Well, that picture is the trans case showing a bent-over hose nipple on top. I'm not real sure about the mount, but I suspect it attaches with the studs #11 & 12. You said the hose is attached one end to a hose nipple on the trans case?
Old Feb 22, 2012 | 09:05 PM
ghostpilot's Avatar
Hey Danny,
I have the same car and on the right side ( passenger side ) there is a little hose that is being squished by the motor mount. Mines is not connected either. I though that it went somewhere and that maybe a mechanic had accidently left it unattached. Either way I hope my answer helps.
Old Feb 22, 2012 | 09:16 PM
Originally Posted by ghostpilot
Hey Danny,
Why are you keep posting on threads that are almost a year old?
Old Feb 23, 2012 | 08:34 AM
ghostpilot's Avatar
Hi Redbull,
Well mainly because I just aquireded the PDF repair manual for my car which is the 99 EX and I thought I would help. When I originally came across this website it was by searching via Google for very specific problems and I found the answers were on threads that were very old. I just wanted to contribute since I thought it might help someone since I had this manual.
