HELP ---ENGINE OVERHEATING
Old Jul 10, 2006 | 07:30 AM
isuboy's Avatar
Default HELP ---ENGINE OVERHEATING
I HAVE A 1996 HONDA ACCORD LX ....MANUAL TRANSMISSION.
YESTERDAY I NOTICED WHEN THE CAR IS IN STOP MOTION THE TEMP NEEDELE WOULD BE HIGN IN RED AREA , SO I IMMEDEAELY STOPPED AND TURN OFF MY CAR AND PUT ANTI FREEZE SINCE IT WAS EMPTY ...THEN EVEYRTHING WAS FINE
TODAY I WAS COMING TO WORK AND FOUND THE SAME PROBLEM ......WHEN I AM DRIVING THE NEEDLE WOULD GO BACK TO NORMAL AND WHEN I AM STOP IT GOES BACK TO HIGH AGAIN .....AND THE WORSE THING IS I JUST FOUND THAT THERE IS LEAK IN THERE SOEWHERE ..........I FOUND COLLENT ALL OVER THER GROUND ...LOOOKS LIKE ITS COMING FROM SOMEWHERE FROM FRONT LEFT CORNER OF THE CAR
I DUN KNOW I AM KINDA SCARED ......I AM JUST STUDENT DUN HAVE MUCH TO FOR A MAJOR REPAIR .....
PLEASE ANYONE TELL ME WHAT COULD BE THE PROBLEM ....I AM GUESSING RADIATOR LEAK ......
PLEASE ANYONE LEMME KNOW HOW MUCH IT COST TO FIX ANYTHING RELATED TO ENGINE OVERHEATING
THANKS
Old Jul 10, 2006 | 07:49 AM
YeuEmMaiMai's Avatar
Default RE: HELP ---ENGINE OVERHEATING
Most likely you have a leak in your radiator.
If you are even more lucky, you can replace radiator, refill cooling system, and bleed it and you will be good to go.
If you are unlucky you overheated your car one too many times and blew up your head gasket.........
Old Jul 10, 2006 | 08:25 AM
mbo1985's Avatar
Put come coolant in the system and start the car. let is warm up to temp and check for leaks. If it's a busted hose, then it's not a whole lot. If it's coming from the radiator, then it's going to be more money. I would do this first, just so you know what's going on and don't get taken.
Old Jul 12, 2006 | 03:43 AM
deserthonda's Avatar
pressure test the cooling system and locate the leak.........if it is a 4 cyl.. no hoses on left side of car ( driver side ) possible radiator or water pump leak
if it is a v6 different story..
input the year and model on your signature so we all know what car you got, it helps us give you the correct information first time around
Jeff 1990 Accord EX 2.2L AT
Feb 22, 2012 07:17 PM
cloakzore
Oct 24, 2011 06:08 PM
mamtsberg
Mar 17, 2010 09:15 PM
grgo
Aug 22, 2009 02:25 PM
