Help!!! I just swapped my engine and....
Old Jan 2, 2009 | 04:29 PM
JP98's Avatar
Default Help!!! I just swapped my engine and....
I just swapped my 98 Accord's F23A4 engine with a F23A4 off a 2002 sedan and the fans dont turn on by themselves.... They work when I turn the AC on (I tried only to test it) I have everything plugged in as I should for the looks of it... Please help. Anything I forgot to do???
Edit***** Added info....
The reason I swapped the motor is because I BHG. The oil got into the coolant... the coolant did not get into the oil. I cleaned the radiator out completely, bought new hoses, (top and bottom rad hose, and heater hose) Cleaned out the reservoir hoses (2)
Old Jan 2, 2009 | 10:13 PM
JP98's Avatar
Default RE: Help!!! I just swapped my engine and....
Do you guys think its the temp sensor gone bad??? Maybe my cleaning of the radiator was a bit harsh? A fuse?
Old Jan 2, 2009 | 10:17 PM
finch13's Avatar
I know there is a thermoswitch A and a thermoswitch B that turn the fans on at the correct temperature.... and I know they can god bad.
Old Jan 2, 2009 | 11:04 PM
JP98's Avatar
The new engine has 46k on it... the fans worked fine before the swap.... By the way, my temp gauge stays at its normal running temp (1/3), although I think its running warmer than usual. Please help me out I cant believe Im having this problem with this swap.
Is there a way to test the switches? Or do I have to buy new ones?
What about the sending unit? Where is that located and would it be easy amd inexpensive to change?
Should I flush out the cooling system?
Check the timing on the engine?
Can it be time for a new t-stat and or WP???? I know I have to get the T-stat from Honda (OEM) like all hondas/acuras, I have a new WP on the old engine....
Old Jan 2, 2009 | 11:14 PM
finch13's Avatar
Things I would do:
- Bleed the cooling system
- Check the switches for the fans, force the circuits closed and see if the fans actually run
-Timing shouldnt effect the cooling system
-A new T-stat or WP shouldnt affect the fans turning on or off
-The sending unit is not connected to the fans, it only tells teh gauge what to read
-My guess is the thermoswitches were damaged or bad on the new engine.
Use the link in my sig to search for "thermoswitch", there might even be a DIY in the DIY section.
Old Jan 2, 2009 | 11:23 PM
JP98's Avatar
I always use your search.... I google your name everytime I jump on because I use your search... Haventtrued searchingthermoswitch yet though. Again, thank you so much for your help Finch... Ill search that right now and try to diagnose. Im gonna have a long "to do list" tomorrow.
Finch, how do I Check the switches for the fans, force the circuits closed and see if the fans actually run
Also, every ????k miles should I replace the Tstat?
Old Jan 2, 2009 | 11:26 PM
finch13's Avatar
I would just unplug the fans and give them direct current from the battery to see if they run without any switches in the circuit.
As for checking the actual switches, I know its been mentioned on here before, I just dont know how exactly. Good luck though!
Old Jan 2, 2009 | 11:34 PM
JP98's Avatar
They should work.... They work when I turn on the AC... Ill try first thing in th emorning and shoot you a om and post as well. Thanks a lotagain
Old Jan 2, 2009 | 11:36 PM
In 98 theres only ONE fan switch. Its located in the thermostat housing. The fan WILL NOT run after the key is switched off.
Unplug the fan switch. Jumper the wire with a paperclip. Key on, that should make the fan run. If so, you have just tested EVERYTHING except the switch itself.
Old Jan 2, 2009 | 11:37 PM
finch13's Avatar
I think the fan closest to the A/C compressor turns on with the A/C, but the other one doesn't, but I'm not 100%...
Im driving back to MN from FL tomorrow, so a PM might not be the best idea. I check every new post, so just post in here and I'll see it as well as other people.
