Help!!! I just swapped my engine and....
Old Jan 3, 2009 | 03:02 PM
JP98's Avatar
Default RE: Help!!! I just swapped my engine and....
sounds good... I grabbed my old harness and saw that the little plug was hacked off... Im gonna try the paper clip thing. The one on the Tstat housing rigt? Im on it!!!
Old Jan 3, 2009 | 03:05 PM
JP98's Avatar
If it is the switch (sensor) thats messed up, how do I change it with my other one? Theyre hooked up to a million things
Old Jan 3, 2009 | 03:21 PM
It wasn't clear from your last two posts, but you should short the wire harness side of the temp. sensor and not the sensor itself.
Old Jan 3, 2009 | 03:33 PM
JP98's Avatar
I just warmed it up and found out that the lower rad hose stays cool.. while the top get hot. Does that mean it could be the tstat?
Old Jan 3, 2009 | 04:01 PM
If T'stat is stuck open, the coolant temp may never reach temp for the thermoswitch A to close (195F I think), so fans never run. In cool weather, thermoswitch A may not close unless you run the car at speed and bring to a halt w/ engine idling.
An infrared gauge or OBD2 monitor to know the coolant temp is helpful.
Old Jan 3, 2009 | 06:03 PM
JP98's Avatar
I just switched the switch above the tstat housing.... Fans come on now. Thanks to all of you for the help.
1 last problem. I disconnected a little hose thats clipped on top of the lower radiator hose... From the looks of it, both ends... Where dpes that go?
Old Jan 5, 2009 | 11:46 AM
  #17
If the radiator is clogged, it could cause the lower hose to stay cool while the upper one gets hot. The reason is the flow rate is small so what little flow goes thru the radiator will have plenty of time to get cool.
Hersheybar06
Aug 3, 2013 09:12 PM
alkemyst
Apr 10, 2013 10:42 AM
Boosted95
Jan 28, 2011 10:05 PM
aboutblank29
Oct 19, 2007 12:15 PM
LaminatedKitten
Aug 15, 2006 09:35 PM
