95 Accord Swapped and Boosted WIRING PROBLIM HELP
Old Jan 28, 2011 | 03:42 PM
Boosted95's Avatar
Default 95 Accord Swapped and Boosted WIRING PROBLIM HELP
Well lets start off by sayin i have had my battery and altanater tested when i drive all my gauges go crazy my hot and cold jumps all the way hot and speedo and rpm gauge quit workin i had it tested also while car was runnin and only put out 12.49 volts it has a after market alarm and push button to start ANYHELP PLEASE
Old Jan 28, 2011 | 04:42 PM
Is the gauge just going crazy, or is the car running poorly? Was this happening before you did the swap?
I would download the 94 shop manual from spooner link in Online manuals thread in the DIY section.
Clean all ends of both battery cables along with the connections to the alternator. Also, check all grounds in the engine compartment and in the cabin. I would clean the bolt threads and the eyelet with a wire brush and/or sand paper.
Use the shop manual under electrical, wire harness and ground location to find all of the grounds to clean and tighten.
Old Jan 28, 2011 | 06:26 PM
Boosted95's Avatar
it just started to do it the swap has been in for a long time ill look at the grounds tho anymore help thanks
Old Jan 28, 2011 | 09:42 PM
Boosted95's Avatar
Whats the website
Old Jan 28, 2011 | 09:57 PM
g22cd5's Avatar
Supper Moderator
also what engine did you swap? What is your set up? How was it running or was it even running be4 you had this issue? Did you do anytype of wiring when you did the swap? Need few more details
Old Jan 28, 2011 | 10:05 PM
Boosted95's Avatar
Its a jdm f22b it runs fine just does that **** and it will die over night also heat cuts in and out and when u turn lights on it makes it worse car wont shut off tho
alkemyst
Apr 10, 2013 10:42 AM
Boosted95
Dec 27, 2010 04:40 PM
JP98
Jan 5, 2009 11:46 AM
sUbLiMe96
26
Dec 16, 2007 09:41 PM
aboutblank29
Oct 19, 2007 12:15 PM
