HELP NEEDED - Unusual Shift Lock Problem
Hi all,
After warming up my 2001 Accord V6 for about 5mins today, and swithch gear shift to reverse to get out of the garage, my engine suddenly cut out. And the shift is locked in Park position.
I read a bunch of posts online and tried to manual shift release. Which does allow the shifter to move out of Park, but the STRANGE thing is that, althought the engine can start up fine, the Tachometer never move out of 0, and the fuel gauge is at 0 (even the tank is full), Temperature is at 0... as if all these gauges are not working.
Here's what I've tried so far after reading many posts:
1) Brake lights are all working fine
2) Horn works
3) I can start the engine fine, but shift is locked to park. After manual release, if I shift the gear, engine will make an unusual sound (like as if accelerating for a second). Feels like a rough shift each time. If I put it into park, and shut engine, it will be locked again...
Any suggestion would be greatly appreciated!!! Thanks in advance!
2) Horn works
How about a code. Has the engine kicked the CEL on? I would almost bet it would and if not wonder why. Does the CEL come on when the car is started and then go off? Another words does it work?
Could be a number of things going on such as a bad brake switch which sends signal to the solenoid for the shift lever, the solenoid itself, shift position switch, PCM. The problems should be check in that order from brake switch by the brake pedal to the PCM.
Maybe just a bit more information might help.
So I've checked again, CEL is not on. Also found out that the Power Windows are not responding. Beginning to think its an electrical issue... But check all the other (windshield wiper, all signals and lights, radio, a/c, power mirror etc) all works fine....
Any thoughts?
Any thoughts?
I have a suspicion, I've installed an aftermarket backup radar a long time ago. The power is drawn from the backup light wirings. (ie. if I shift to Reverse, the radar is powered). I noticed the wire of the radar has worn off. If this wiring (connected to the backup light bulb socket) shorted, where would I check first for something that's fried? Is it the MICU as last post suggested?
Did more digging on the forum and found a post with the exact same symptoms as me... however, the original poster fixed the issue but did not post a solution. Sounds like putting in a fuse as it got shorted out:
https://www.hondaaccordforum.com/for...t=power+window
I'm a newbie to changing fuse, so it would be a big help if someone could give some directions on how to locate the correct fuse and how to replace it?
Thanks so much!
Thanks so much!
