HELP! OIL IN MY MUFFLER TIP!!!! ADVISE PLS!
Old Dec 26, 2006 | 05:49 AM
juanortanez031278's Avatar
Default HELP! OIL IN MY MUFFLER TIP!!!! ADVISE PLS!
I just bought this accord exi1996 model philippine version 2.0 engine none VTEC 2months ago, anyway i found some oil on the tip of my muffler every time i use it, the car drives well in ultra heavy traffic, no over heat, just some white smoke coming out of the muffler every morning then goes away after a few min. then just a week ago i observed that there was oil on the tip of my muffler...
could anybody advise me as to what to do or where to check? thanks!
Old Dec 26, 2006 | 08:30 PM
hondadude's Avatar
Default RE: HELP! OIL IN MY MUFFLER TIP!!!! ADVISE PLS!
It might just be carbon and water vaporcondensation that you are seeing, is the engine using a quart of oil a week?
Check the PCV valve in the valve cover?
Old Dec 26, 2006 | 09:48 PM
sir_nasty's Avatar
I agree with hondadude.... I also posted a similar reply to the other post that you made...
Old Dec 26, 2006 | 11:34 PM
thanks for the reply guy!
yes my motor eats up oil like a quart in 2 weeks... andlast night i touched themuffler tip it was oil![]hmmm hondadudeis the pcv valvein the valve coveris thehose sticking out on top?after that what should i check or observe? thanks!
Old Dec 27, 2006 | 05:16 PM
sir_nasty's Avatar
the pcv is the one sticking out of the top of the valve cover... I don't recall what the test procedures are sorry.... I've cleaned them but never had to replace one.... I'm sure they are cheap even if you had to buy a new one....
Old Dec 28, 2006 | 11:19 PM
MichaelEXL's Avatar
I was at the dealer one day, and someone came in with one that did the samething, needed a rebuilt engine, it was about$1800.00 and if done at the dealer they willwarranty the engine. I have a 96 Accord EX-L with 192,000 and just had the selas replaced and the timing belt done.
hondan1997
Jun 21, 2014 10:47 AM
dre707
Feb 9, 2011 11:51 PM
92accord808
Sep 8, 2009 07:19 AM
00raver
Aug 22, 2007 10:29 PM
03Sleeper
25
Aug 10, 2007 11:18 PM
