HELP plz! alohas
Old Jan 11, 2013 | 10:45 PM
csk.jfoxx's Avatar
Default HELP plz! alohas
Wassup everyone,
New to the site here and need some help. have a 96 lx accord did an ex engine swap, slowly building the car and i just cant get rid of that damn "Cylinder Position Sensor no signal code". Been researching and cant figure it out. put in a whole new distributor check all the wires, connections, cleared the computer and it just keeps coming. please help. thanks a lot
Old Jan 12, 2013 | 08:15 AM
What was the year of the donor engine?
What ECU are you running?
Old Jan 12, 2013 | 07:01 PM
csk.jfoxx's Avatar
I'm running the vtec ecu I don't know the year but it's an f22b1 and I got the engine code if that would help
Old Jan 13, 2013 | 09:39 AM
What I'm trying to figure out is if the engine and ECU are "matched".
The 94-95 Accords are OBD-I. The 96-97 are OBD-II. So some things are a bit different between them.
What is the actual code number you are getting?
Old Jan 13, 2013 | 08:43 PM
csk.jfoxx's Avatar
im getting p1382 and thats the only problem. other than everything is running perfectly fine. thanks for the help
Old Jan 14, 2013 | 08:43 AM
P1382 = CYP sensor no signal
I think they changed the sensor signal scheme between OBD-1 & OBD-2. Not only the location of the CKP & TDC sensors, but the details of the signals from all 3 of the timing sensors. Are you using the distributor that matches to the ECU?
Just saying F22B2 doesn't tell us everything. But the first digit of the block serial # should indicate the model-year of that engine.
Old Jan 15, 2013 | 06:36 PM
csk.jfoxx's Avatar
yea im using the right distributor. ill get thatserial # and post back.
Old Jan 16, 2013 | 06:41 AM
I'm not sure of the first year that F22B2 was available, but the first digit of the block serial # counts from there. So 1 is the first year, 2 is the second year, etc.
Old Jan 28, 2013 | 01:58 AM
csk.jfoxx's Avatar
Hey sry for taking so long just been busy. But my engine came from a 96 2 dr coupe ex and i swapped into a 96 dx not lx
Old Jan 28, 2013 | 09:33 AM
Roader's Avatar
Are you running the internal coil distributor from the F22B1? Or the external coil distributor from your old F22B2?
