help putting back tranny.
guys im putting back my tranny today bolt the torque converta blots on connect up the shifter cable put the car in drive and the converta is not spinning, if i spin the wheel the other wheel spins but not the converta ived tried it in all different gears, i didnt put any tranny fuild as yet can this cause it? if i turn the crank pully it turns the converta but not the wheels the car is on a hoist.
[ol][*]
i didnt do these steps as yet can this cause it.[*]
Install the starter. Connect the cables to the starter. Connect the lock-up control solenoid valve and shift control solenoid valve connectors. Connect the speed sensor connectors and the transaxle ground cable. Connect the transaxle cooler hoses to the joint pipes. [*]
[/ol]
[/ol]
Did you bolt the converter to the flex plate? It almost sounds like you did everything but that. I'm not busting you or anything but, thats something i would look into. In case you have'nt. Hope this helps.
i got the car running today, i pour way too much ATF could this cause harsh shifting? also im using dexron 3, i cannot move the shifter out of park unless i stick the key in that slot and move it. also if i try to put the car in park with it running i can hear the tranny making noises like if something is caught of hooking inside the tranny, maybe this is the reason y the flex plate broke, all other gears are fine.
Hector215
Apr 13, 2013 02:23 PM
HondaAccordEX94
Nov 28, 2010 01:56 PM
2006 Accord EX Experiencing vibrations on my acceralator padel in initial gears while putting on gas
thinkliquid
May 13, 2006 03:17 PM
