HELP!!! Rough idle and bad millage HELP!!!!!
Old Apr 29, 2012 | 02:57 AM
Jesus Pickles's Avatar
Default HELP!!! Rough idle and bad millage HELP!!!!!
I have a 1997 accord 4 cylinder LX and I've been having one problem after another so recently i had oil in spak plug 3 and 2 so i had the seals and everything replaced so then it started to idle rough and then it started to just randomly die on my when i was driving so i took it to a mechanic to do test on it and he said that it was ignition switch and it was misfiring. So he said the ignition switch was a recall so i took it to a honda dealer the replaced the part free of charge and it still idles rough but doesn't die on me but now im getting really bad gas like about 100 miles to half a tank.
Could it be my spak plugs? I just replaced the wires so i know those are good.
And could when i had oil in the spark plugs cause the spark plugs to be damaged and need replacing.
HELP PLEASE im going broke with this car!!!!!
Old Apr 29, 2012 | 03:30 AM
Could it possibly be a vacuum leak? or maybe a bad ERG Valve
Old Apr 29, 2012 | 08:44 AM
crispin's Avatar
short the 2 pin connector under the glovebox and report what codes you fine back here.
Read the 'How to pull codes' thread in the DYI section of this website
Kpick
May 5, 2015 08:51 PM
HatchJunki
Mar 9, 2013 08:23 AM
giulio76
Dec 29, 2012 11:16 AM
NEPORTLANDMV
Apr 27, 2012 12:21 AM
bkearney
Mar 15, 2012 06:40 PM
