HELP??Trying to Start 00 Accord With External Pump/Tank
Old Sep 2, 2015 | 03:26 PM
jweb's Avatar
Default HELP??Trying to Start 00 Accord With External Pump/Tank
I posted a thread a few days ago about a sensor on the fuel sending unit of a 00 Accord EX 3.0 Coupe. I somewhat have it figured out but now I have another problem. As mentioned, I'm in the process of starting a fuel tank replacement and I need to move the car before I start. It would run and drive if it could get fuel to the engine so I set up a fuel pump (external pump that I use on my engine run stand to run LS1s and LS6s, so far) in the trunk with everything needed to pump fuel into the fuel line. The Honda tank has a line to the engine and another that's a return. I plumbed the return back into the OEM tank and connected the other line to my external pump that has a inline filter just before it goes into a fuel jug with fuel. I was alone when I tried it so I couldn't tell if the fuel pump was running as the key was turned to run. I did connect it to another battery to try to prime the fuel to the injectors. It was in direct sun here in Texas so I pretty much gave up after getting it to start on starting fluid then dying after that was depleted. I did wire the external pump through the sending unit so it would connect to the trunk harness but I only connected the 2 wires that power the pump. I must be missing something if anyone can help me. Thanks
Old Sep 3, 2015 | 12:51 PM
Turtlehead's Avatar
We always use a tow rope to move cars around that don't run. I will be doing it again next week when I swap the complete drive train and axels from one Acura TL to another with a good body. Sorry, I can't really help with this other then just tow it and use manual labor to get it into your working area.
Old Sep 3, 2015 | 06:27 PM
jweb's Avatar
No problem. I got it going today...the pump I was using didn't have enough pressure. I just set up the new pump in a temporary jug. Ran great and the AC still spit ice cubes. If anyone ever needs to do this, the computer isn't an issue when jumping the pump. Thanks
Rilex
Aug 14, 2015 12:04 AM
hohodang
Apr 7, 2015 04:11 AM
Hidden lights
Mar 9, 2015 10:54 AM
jessecolter
Sep 2, 2012 08:58 PM
