Help with windows 97 accord coupe
Old Jul 12, 2011 | 01:20 PM
Default Help with windows 97 accord coupe
A while back i took out the dash and removed the heater and ac boxes. Now that the car is back together the windows, door locks, and power mirrors do not work. The moon roof however does work.
Its 90 degrees out today and its awfully hot driving around with the windows up.
I have checked the fuses and they are all good. Can someone tell me where all the connectors are that I should check, or any other things I should check.
Also would it be that hard to go to the junkyard and get the crank assemblies out of a dx and swap them in?
Old Jul 12, 2011 | 02:23 PM
I would start by testing the input for the driver's side master switch. Hopefully you are missing voltage or ground on a wire, then you will be able to work backwards.
The switch is pretty simple to remove. Search 0_Z8lE5zC0o on YouTube for a good video.
Old Jul 12, 2011 | 03:36 PM
I put a volt meter to every wire on the driver side window switch. 2 had 12 volts all the rest had 10.8 volts.
Old Jul 12, 2011 | 04:39 PM
I would also check grounds at G401 and G402, as the power windows, locks, and mirrors share those grounds.
Old Jul 12, 2011 | 04:43 PM
Can you tell me where those grounds are? I dont have a haynes or helms manual
Old Jul 12, 2011 | 04:55 PM
Here are the locations:
Attached Thumbnails Help with windows 97 accord coupe-g401.jpg   Help with windows 97 accord coupe-g402.jpg
Old Jul 12, 2011 | 05:35 PM
Those grounds appear to be good.
Old Jul 12, 2011 | 06:19 PM
You can download the 94 shop manual from the link below. The spooner link works.
https://www.hondaaccordforum.com/for...-manuals-4597/
That manual is almost identical to the 96, except for some changes. The testing of the master switch is the same.
Old Jul 13, 2011 | 10:36 AM
I gave up and ordered manual regulators from rock auto $55 each compared to the $120 a piece the local honda dealership wanted.
Turns out only 94 coupes were offered in DX
ion_IX
Oct 26, 2012 06:28 AM
RaysHondaAccord1994with247.000miles
Oct 3, 2011 07:29 AM
secureone
Mar 19, 2008 11:02 AM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
