HELP! Wont start, radio flashes....
Old Aug 6, 2007 | 12:30 PM
xcrunner19420
Default HELP! Wont start, radio flashes....
I have a 98 accord V6 and have never had a problem with it until today. The car wont turn over, but the radio flashes and makes a clicking noise when I turn the key, any suggestions?
Old Aug 6, 2007 | 01:18 PM
sir_nasty's Avatar
Default RE: HELP! Wont start, radio flashes....
Does the car make any noises when you try to start it? clicks etc? Make sure your battery cables are clean and well connected. Then let us know if the clicking noise is coming from the engine bay or the radio... It sounds like a bad connection to me (first random guess)
Old Aug 6, 2007 | 01:38 PM
xcrunner19420
Ok, I tried to connections, no luck.The car does make clicking noises when I try and start it.
Old Aug 6, 2007 | 01:52 PM
sir_nasty's Avatar
Okay, then as long as you're certain your connections are tight and clean. If you have a voltmeter test the battery to make sure it's charged, if you don't have one I'd try to jump start the car, if it does the same thing then we've ruled out the battery. That would indicate a starter celenoid issue (starter basically...) to test that one out get a decent sized wrench or socket, locate the starter, on the side of the main body of the starter is a little round (sometimes square) thing that is part of it, bang on that a decent amount with the wrench/socket (don't kill the thing but whack it good, big dents are bad, little ones are fine) then try to start the car again, if it cranks and/or starts then you know your issue. (bad starter celenoid, usually comes included w/the starter as one piece)
Old Aug 9, 2007 | 11:04 PM
Dazed's Avatar
Im having same problem...i think. Iv pretty much ruled out the battery.
Xcrunner..has ur problem been fixed? What did u do?
Old Aug 10, 2007 | 11:07 AM
sir_nasty's Avatar
Did you check your connections (especially from battery to starter) and try the celenoid test?
Old Aug 10, 2007 | 11:23 AM
Dazed's Avatar
Which is the connection from battery to starter? How can i check?
deserthonda
Dec 11, 2024 04:07 PM
inno87_2k_accord
Oct 12, 2010 07:06 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
EPIFEMIO
Aug 25, 2007 03:32 AM
no_doz
Jul 19, 2006 11:13 AM
