HELPP!!! 1996 Honda Accord f22 to f23 engine swap!!
Old Jul 15, 2019 | 01:49 PM
The Toecutter's Avatar
Originally Posted by JimBlake
You said fuel coming out of the vacuum hose from the FPR to the intake manifold? That shouldn't happen, so it means your FPR has a broken diaphragm & engine is probably flooded. Get a new FPR & let the fuel evaporate from the cylinders.
A long time ago I had a similar problem flooding a car. Spark plugs looked very nice but all the excess fuel had caused them to short internally. If it doesn't start nicely, consider new spark plugs.
I think you're on the right track Jim. My question to the OP is this, did you reuse the 96 injectors? If not, that's a good part of your fuel problem. I say that, because they use a resistor block, while the 98 injectors don't (different style of injector).
Old Jul 15, 2019 | 02:10 PM
Infinite's Avatar
Yea I did reuse the 96 fuel injectors.
Old Jul 15, 2019 | 02:47 PM
Infinite's Avatar
So does that mean that I would have to use the 98 injectors, or do i just take out the whole fuel rail and put it on the 96 intake.
Old Jul 15, 2019 | 05:43 PM
No, it means you should do either of the following...
1) Use the 96 injectors because your car's wiring includes a resistor box in the circuit to power the injectors.
2) Use the 98-02 injectors but remove that resistor box from the circuit. I'd want to see a 1996 circuit diagram for details of just what to do...
Don't forget to check whether your fuel-pressure regulator is blown out. That vacuum line going to the intake manifold is not supposed to have fuel in it.
Old Jul 15, 2019 | 05:52 PM
Infinite's Avatar
Alright thanks man. imma check if its blown or not. As for the injectors ill just use the 96.
Old Jul 19, 2019 | 03:25 PM
Actually it means #1, use the 96 injectors. That way you don't have to rewire stuff (can cause unforeseen problems of it's own).
hondaman86
May 21, 2021 02:38 PM
Accord 96
May 24, 2016 08:44 PM
kshellz
Oct 24, 2012 10:51 AM
marbro
Dec 16, 2011 10:40 AM
AbaZ
18
Jul 16, 2008 10:23 PM
