Hey look its me
Old Jan 28, 2017 | 09:22 AM
TexomaAccord's Avatar
This car is taped together with pieces from several different cars... No telling what all has been rigged up on it.
Old Feb 16, 2017 | 11:35 PM
The engine is a f22a1 -- auto transmission -- Ok, anyone know which other cars have transmissions that will fit?
Old Feb 17, 2017 | 06:36 PM
Any auto trans from a 4 cyl Accord from 90-97 will fit. Depending on the donor trans there might be some minor wire issues - connectors not matching up but the wires are there.
Old Feb 17, 2017 | 07:54 PM
Good to know.. What about prelude, acura, etc?
Old Feb 18, 2017 | 06:41 AM
Yes, the F and H series engines take pretty much the same trans - prelude, yes.....acura of some sorts, yes.
What I'm not clear on with those is where the "year split". I know the Accords went to an electronically controlled trans in 98....I do not know when the prelude went to the electronic controlled trans.
Old Feb 19, 2017 | 10:55 PM
Discard, Discard, Discard --- lines run to radiator.... going to replace radiator also.. oy vey
Old Mar 18, 2017 | 03:28 PM
  #17
Ok, so installed external trans cooler.. attempted to flush trans (disconnected lines, drained pan, started car, added fluid while catching old fluid in bucket) -- it was clear red fluid, put it in drive, started changing creamy red.. kept adding fluid, would not clear up at all. I let about 15 quarts flow through there, and it still never cleared up 100%.. Tested shift cable. Tried to manually put in reverse, still grinding.. Ugh
Aug 21, 2013 05:41 PM
Mar 29, 2008 01:46 AM
crazyb3e
Nov 5, 2006 09:20 PM
