Hi new here, advice?
Old Jul 6, 2010 | 12:51 PM
deserthonda's Avatar
that price ( $ 390 ) is to bait you to get in,,very misleading ,,it is only to replace the t-belt and maybe balancer belt ,,,,,,find out how much extra they charge to replace water pump, new coolant , all the seals ( cam, crank, balancer, oil pump, valve cover gasket ) and the outer belts
which by the way i strongly recommend that you replace if you are doing a timing belt job
Old Jul 6, 2010 | 07:54 PM
MysticBlueEX's Avatar
Almost A Senior Member
You are likely correct, Teaser!. They would use the "Available Balance Detector" and I would be eating Tuna Sandwiches for the next 90 days to get back on budget!
The dealer does have an Oil and filter special, 29.95 with 30 point inspection, I was thinking that the inspection at the dealer can give me some idea of a list of priorities.
Old Jul 6, 2010 | 09:04 PM
Nah...
The list from the dealer won't tell you priorities.
Post up the list & we can suggest which ones are urgent. Which ones are urgent but easy enough for you do to yourself. Which ones can wait a couple months. Which ones are BS. Or at least we can help you decide.
Timing belt is important. You don't know the maintenance history, right? You can't really inspect a timing belt 'cause it'll look quite good a month before it breaks. Gotta go by 100k miles or 7 years (whatever your owner's manual says - don't trust my memory). Broken timing belt leads to pistons hitting the valves which is really NOT a good thing.
Old Sep 3, 2010 | 01:48 PM
I did some more phoning around with the VIN # to the 4 nearby Honda Dealers and got these prices for Timing Belt replacement, water pump, balancer belt Parts and Labor.
Dealer #1, $580.00+ Sales Tax Ray Laks 14224
Dealer #2, $499.99+ Don Davis Autoworld 14226
Dealer #3, $489.99+ West Herr Honda Lockport ny
Dealer #4, $825.00+ includes all accessory drive belts. Lia Honda Williamsville NY
Pep Boys Franchise $764+ 14219
Dealer #4 also has all the service records, the service writer looked my car up using the VIN and gave me a summary of the services done since 2005.
Now I know that there is no record of the TB service
Old Sep 3, 2010 | 07:30 PM
dealer # 2 and 3 ,, sounds real cheap for a timing belt kit,, using all honda parts .....
but if they replace all 4 belts, ( timing, balancer, alt, p/s)water pump, coolant and all seals ( cam, balancer, crank, valve cover gasket ) PARTS AND LABOR .... JUMP on it ASAP..........
..Honestly,,, it is hard for me to believe that a Honda dealer will do it for so cheap
Old Sep 4, 2010 | 07:15 AM
Here is the link to the published internet price at West Herr Honda Lockport NY, it does not say anything about balancer belt or drive belts, Lia Honda was the only dealer I spoke with that was quoting the everything and more, the Complete Job
No direct live links allowed in your posts..type in with out the www in your post...Thanks
I can't see any reason that the Honda Dealer would not use Honda parts, do you?
Right now I need to save $200! wife back in college and all so I am going to get the written estimates to compare the actual services that are included in the quoted prices. No sense getting half the job done. I need to bargin this one and and pinch the penny till it squeals!
Also, I can't go into it thinking it's 500 and end up with 900.
Old Sep 4, 2010 | 01:09 PM
  #17
CRZ1's Avatar
I am in NJ. I went to Honda dealer a couple months ago. The price for timing belt, balance belt, power steering belt, compressor belt, water pump is $859. They said they will inspect tesioner and all seals, it needs to replace, I need to to pay extra, I remember $59 for each seal. The dealer can give me 10% off, I went home and find 15% off coupon. So dealer #4 gave you a more reasonable price quote.
Old Sep 8, 2010 | 10:47 PM
  #18
Default Hi Member
PLEASE follow the posting rules for us..Thank You!
Rat Rod Mac
Apr 23, 2015 11:10 PM
7thgenlove
May 18, 2013 01:29 AM
sidthekid
Apr 13, 2013 11:15 PM
Erik Shirk
Aug 4, 2012 12:40 AM
bholloway546
Jan 31, 2009 07:09 AM
