high beam will not stay on
Old May 16, 2012 | 01:10 PM
funkyguy's Avatar
Default high beam will not stay on
have a honda accord 1995..
the high beam will not stay on... when I pull the switch, the highbeam turns on, but when I let go of the switch it turns back to normal....
however, sometimes when its very cold outside, it sometimes sticks in highbeam-mode until my car gets heated up inside...
fixable or do I have to replace the switch?
Old May 16, 2012 | 01:15 PM
crispin's Avatar
most likely
Old May 16, 2012 | 01:16 PM
funkyguy's Avatar
heh...most likely what?
Old May 16, 2012 | 01:18 PM
Probably switch needs replacement.
Old May 16, 2012 | 01:19 PM
funkyguy's Avatar
how about unplugging it, clean it and lubricate it?
Old May 16, 2012 | 01:21 PM
funkyguy's Avatar
Old May 16, 2012 | 01:34 PM
crispin's Avatar
I meant most likely will need to replace switch.
It is a lot of work to get to the switch.
I think it is a better idea to just replace it instead of trying to fix it.
Old May 16, 2012 | 01:37 PM
crispin's Avatar
Actually that is pretty interesting, I had thought the steering wheel had to be removed to access the combo switch.
I would def try the procedure shown, doesn't look that bad at all to do.
Good luck and report back your findings.
Old Jun 11, 2012 | 02:53 PM
funkyguy's Avatar
I pulled out the switch, opened it and cleaned the contacts...
did not help...
Today I replaced the switch with an identical one from another Accord, and it still did not fix the problem..
any other ideas?!
maybe the used switch I bought had the same problem, but I really doubt it...it was pulled from a honda 1995 with 49 000 miles on it
Old Jun 11, 2012 | 07:59 PM
Have you tested the dimmer relay? I would test the inputs to it and then the relay to be sure.....dimmer relay is different than the headlight relay....underhood fuse panel.
