high beam will not stay on
Old Jun 11, 2012 | 08:25 PM
funkyguy's Avatar
Have you tested the dimmer relay? I would test the inputs to it and then the relay to be sure.....dimmer relay is different than the headlight relay....underhood fuse panel.
hmm, I have no idea how to do this .....
how do I test it, and how do I fix it?
Old Jun 11, 2012 | 10:10 PM
Please don't take this wrong....since we are on page two, put your car info in you signature line so we don't have to go back to remember what we are working on......thanks.
The dimmer relay, location already given, should have four pins. When the high beams are on, ground is sent thru the orn/wht to the high beam lights. The red/blu into the relay is the ground that closes/activates the coil in the relay.
Old Jun 26, 2012 | 07:31 AM
funkyguy's Avatar
I ordered 2 relays from ebay and replaced the dimmer relay in my car, and to my excitement the high beams would stay on...
I went for a short drive and tested the highbeams many times and finally thought Ive fixed the problem...but then after 10 minutes, the high beam would not stay on again !! I swapped out the relay and put in the other one I received just to be sure,...it did not fix the problem
so what is left to try?
Old Jun 26, 2012 | 08:53 PM
I hate electrical issues.
Have a volt meter and some time? Also, the testing will have to be done when the lights are not working.
Old Jun 26, 2012 | 10:56 PM
When the high beam goes out, does the blue high beam light in the car stay on? Do the low beam lights stay turned on?
Old Jun 26, 2012 | 11:42 PM
funkyguy's Avatar
the blue light only stay on when the car is giving out highbeam...meaning, I have to flash the light or hold the switch against me...if I let go of the switch, the highbeam goes off and the blue light goes off aswell
the low beam stays turned on, if I understand your question correctly
Old Jun 26, 2012 | 11:46 PM
  #17
funkyguy's Avatar
time yes, volt meter no...Ive never used that before.
is this one good enough for the job ? its the cheapest ive found at the nearest store :
UT 20 B UNI-T | SOS electronic
Old Jun 26, 2012 | 11:50 PM
  #18
where are you located?
EDIT: It seems from the volt meter price, that you are in Europe. The manual that you can download from the common diy thread covers some European accords. I am just trying to figure out how this shop manual identifies your accord. What trim level is your car, LX, DX, EX, 2.2iES,...?
Old Jun 26, 2012 | 11:55 PM
  #19
funkyguy's Avatar
im in norway...why do you ask?
Old Jun 27, 2012 | 12:06 AM
  #20
funkyguy's Avatar
Honda accord 2.0i
