Hitachi Distributor Internal Seal
Old Mar 18, 2013 | 06:45 PM
rob.c1989's Avatar
Default Hitachi Distributor Internal Seal
Im not sure if anyone has found this before or not, but after doing a lot of ebaying, i found a seller that has the internal seal and the outer oring for about $10
.ebay.com/itm/honda-distributor-shaft-seal-for-F22B1-F23A1-F23A4-and-F23A7-with-o-ring-/180970632380?pt=Motors_Car_Truck_Parts_Accessories &hash=item2a22b0b4bc]Honda[/url] Distributor Shaft Seal for F22B1 F23A1 F23A4 and F23A7 with O Ring | eBay
Old Mar 26, 2013 | 11:24 AM
grannie613's Avatar
I just noticed your post from a week ago. I too had a similar problem several months ago. Check the photos I posted on 10-30-2012 under PHOTOS. So far, the oil leak into the distributor has stopped. Jim
Old Mar 26, 2013 | 12:06 PM
Roader's Avatar
Those photos and comments should be part of a DIY. It would have helped out someone who posted on this problem a few weeks ago.
Old Mar 26, 2013 | 01:58 PM
firefighter44's Avatar
Almost A Senior Member
From what i saw in the pics it looks as though you changed the outer oring. the only way to get to the inner oring is to get that pin out on the outer side. I took my dist off recently and replaced the outer oring but was unable to get that pesky pin to come out so i was unable to replace the inner ring even though i have one laying around
Old Mar 26, 2013 | 04:24 PM
Roader's Avatar
Firefighter, look at his pics again:
I drove the pin out with a 1/8" pin punch cradling the gear in a notch cut in a 2X4 held in a vise. It is tight! 5/32" punch with a heavy hammer would work better than what I used.
Do not pull or turn the shaft bushing like I did! (Added by grannie613 on 10-30-2012 07:23 PM)
There's more. The pics and verbiage should be in the DIY section.
Old Mar 26, 2013 | 04:50 PM
rob.c1989's Avatar
thanks for the comments. i havent put mine in yet. i couldnt get the pin out of the end piece. so i gave up until another time lol
Old Mar 26, 2013 | 05:32 PM
I just looked at that photo album.
Grannie, if you write up the steps, with those photos, as the next couple postings in this thread, I can move them over into the DIY section. (any moderator can do that).
Old Mar 29, 2013 | 08:56 AM
I just moved it over to DIY-Answers. Thanks for the write-up.
Old Jun 17, 2013 | 04:10 PM
jkowtko's Avatar
grannie613
DIY Answers.
19
Nov 21, 2018 09:26 AM
hallstevenson
May 7, 2015 01:59 PM
bsdubois
Nov 26, 2014 10:02 PM
Stiffy
Mar 9, 2009 12:44 PM
