Hole in gas tank
Old Apr 4, 2007 | 03:58 AM
bigsquid
Default Hole in gas tank
96 accord LX coupe. In cleaning up the trunk well, I noticed the smell of gas, and discovered a screw about 2 inches to the left of the fuel sending unit access cover (as you're looking in from the trunk.) It looks like the previous owner drilled through the tank looking for a ground for the sound system, then just put a screw (#10, about 1/2" long) in the hole to keep fumes and gas from leaking out.
I've heard that epoxy with mesh can patch the hole. Can I fix the hole from inside the trunk? Or, do I need to pull the tank out to do get at the top side of the tank?
Old Apr 4, 2007 | 04:15 AM
deserthonda's Avatar
Default RE: Hole in gas tank
ORIGINAL: bigsquid
Only you can tell that ,, do you have clear access to patch it properly from the top ?? if yes I would do it from the top,, If not then you might have to remove the tank to repair it properly
bjr001
Nov 25, 2010 12:05 AM
play4801
Dec 11, 2006 01:31 AM
shastylz
Dec 9, 2006 05:20 PM
iridebmx33
Nov 21, 2006 08:51 PM
compassltd
Jun 9, 2006 12:03 AM
