Honda Accord 1987 LX -- While PARKED, RPM raises and drops constantly
Old Nov 22, 2010 | 07:29 PM
Honda Enthusiast's Avatar
Default Honda Accord 1987 LX -- While PARKED, RPM raises and drops constantly
Hello,
So a new problem, well... a problem that my car has always experienced is that, when parked for 20 secs - 1 min, the rpm begins to fall and rise sharply from 1-2 and vice-versa constantly all while parked.
This has happened before WHILE driving, but my coolant was low and I addressed the issue on the spot, and was fixed. This issue is only when the car is parked...
Is this a coolant issue? What other issue could this be? I have a brand new car battery, and a new starter.
Regards!
Old Nov 22, 2010 | 08:59 PM
Hello,
I did some research and everything points to the sensor fault. Is this a good place to start checking?
Old Nov 22, 2010 | 10:01 PM
You are having the coolant temprature sensor checked...Yes?
Old Nov 22, 2010 | 10:09 PM
Lightbulb Take A Look At This Item
It should look about like this Image below.. click image for bigger picture.
Attached Thumbnails Honda Accord 1987 LX -- While PARKED, RPM raises and drops constantly-213-725.jpg
Old Nov 22, 2010 | 10:33 PM
1987 LX has a carburator, so it probably doesn't have THAT sensor.
Or is it an LXi ??
Better yet, WHAT sensor did you mean in the second post?
Old Nov 23, 2010 | 04:41 PM
So my coolant temperature sensor should look like that? If it doesn't what would it look like? I need to find where it is, but I'll definetly check that.
My Honda 1987 LXI is a fuel injector.
Old Nov 23, 2010 | 07:50 PM
The surging idle can be caused by air in the cooling system. There's a little air-bleed bolt in the thermostat housing (#22 in the picture). Open it a bit & see if air comes out.
I looked around the parts drawings for 87 LXi and I didn't find the temperature sensor. I hope someone chimes in who knows...
Old Nov 24, 2010 | 01:34 AM
From the shop manual you can download from the online manuals thread in the DIY section, there is a sensor in the radiator.
Also look to see how to properly bleed air from the system when refilling coolant. That could also be your problem.
Old Nov 24, 2010 | 01:18 PM
deserthonda's Avatar
if it is a LXI could be the inner valve in the fast idle valve that is loose,,,,,,,,remove 1 screw and loosen the other, flip the top cover to the side get a flat tip screwdriver and tighten the inner valve till it bottoms ...DO NOT OVER TIGHTEN IT ..
Old Nov 25, 2010 | 12:10 AM
IH8SPM's Avatar
The part near #25 could also be clogged. It controls idle via the antifreeze temp in the engine. Remove and clean screen and replace. You also just have air in your system or a small leak in one of the your hoses or radiator. Honda's are known for the hunting idle issues especially when there a problem with the coolant.
