Honda Accord 1992 DX Help.
Old Jul 12, 2020 | 11:48 AM
vncnt78's Avatar
Yes, the coolant leaks were due to the old hoses giving out. Coolant is not the problem anymore, I thought I just add that fact in so maybe it can help a little on figuring what the collective problem may be.
Old Jul 13, 2020 | 12:28 AM
I'm not sure how frequently or how long you were running the engine with high temperatures, so you should try the test I suggested when pulling the radiator cap on a cold engine. It is a quick test and may identify a headgasket problem.
Air in the cooling system can also cause strange idle problems. You may want to get a radiator pressure tester as a loaner tool most parts stores have. Pressure the radiator to ~15 or 16 psi and see if your cooling system can hold that pressure.
Another fairly simple test is to do a compression test on each cylinder just to verify the mechanical part of your engine is working properly.
A quick test for the EGR valve on your car is to unplug the vacuum hose going to the EGR valve and plug the vacuum hose with something like an old spark plug. See if your problem goes away after running the car.
Old Jul 28, 2020 | 08:33 PM
nomad2020's Avatar
I agree with PA Honda, i would do a compression test make sure engine is running on all 4
hippohat
Sep 10, 2018 09:45 PM
Reanna
May 12, 2017 03:33 PM
Bluezriff
Jun 1, 2007 09:21 AM
JessicaS
Mar 4, 2007 05:58 PM
needshondahelp
Sep 6, 2005 11:36 PM
