honda accord 1994 special edition problem
Old Dec 27, 2014 | 06:55 PM
gagandeepd1's Avatar
Default honda accord 1994 special edition problem
Need to know if there is anyone that can help with replacing and diagnosing the tcutcm in hayward.
Old Dec 27, 2014 | 07:28 PM
What are your symptoms? No start, no crank, poor performance? details needed.
Old Dec 28, 2014 | 12:20 PM
The d4 light blinks really fast and the gear won't shift from the park position. Tried replacing all the solenoids abd main relay and added a used transmission because old one got bad. Been having this problem for over a year now. Need someone that can tell if the tcu or tcm ecu is bad. And if it is there someone that can fix it. Iam in Hayward , CA.
Old Dec 28, 2014 | 04:24 PM
First get the TCU code that is present (D4 light blinking means a code is set).
Short service check connector, turn keyswitch to On, and watch the D4 blinks. One long blink, followed by code where Long Flash (F) =10 and short flash (f) =1. So flashes F-ffff = 14, a long pause will separate multiple codes or repeat of same code.
Post code for guidance.
Failure of gear shift to move can be simple; brake light not working or mis-adjusted lock-out solenoid, or faultly keyswitch. What happens when you bypass the lockout w/ a key in the bypass opening?
jpenn24
Sep 30, 2013 01:41 PM
edpup316
May 20, 2011 10:03 PM
07_Accord_SE
Jan 28, 2011 09:55 AM
boomer714
Feb 27, 2010 07:41 AM
pwe8
Sep 19, 2008 11:30 PM
