Honda Accord 1995 VTec 4-Cyl AT Oil Leak Help
Old May 24, 2014 | 11:04 PM
Tri Vu Vinh Bui's Avatar
Default Honda Accord 1995 VTec 4-Cyl AT Oil Leak Help
Hi,
I am hoping someone could help me pinpoint the location or what to check to see where an oil leak is coming from in my 1995 Honda Accord Vtec AT. I have a few pictures attached that shows where it is pooling. But I have not been able to isolate the origin.
When it is parked, the pooling is slow (maybe 1drip/few hours). But when the engine is idling, the oil drips once every 10-15 seconds.
imgur: the simple image sharer
Any suggestions is appreciated.
Thanks,
Tri
Old May 24, 2014 | 11:10 PM
Take a look under the distributor, the external o-ring is a common leakage area after so many years.
Old May 25, 2014 | 06:28 AM
Also check the vtec solenoid - back pass side of the cyl head.
Old May 27, 2014 | 12:30 AM
Thanks for the suggestions. Looks like I have a leaking vtec solenoid.
Old May 27, 2014 | 07:20 PM
Just note there are two o-ring gaskets for these. Suggest that since you are there, replace both. The top one is easy, the lower one where it seals to the head is a bit of a pain to get to - we all have different stories on how we do/did the lower.
Old Jun 1, 2014 | 01:10 AM
Update: So finally found some time today to replace the gaskets on the vtec solenoid. Did it with a c-shaped wrench without removing the coolant lines (thank goodness).
Anyhow, seems like there is still a minor leak, but no more drips per 10-15secs. Seeing several drops in different locations now; maybe repairing the main leak from the vtec solenoid now the oil has found other locations to exit. Well, got a cardboard under the car to see where the minor leaks are dripping from.
Old Jun 1, 2014 | 11:16 AM
Sometimes a clogged PCV valve will allow the crankcase pressure to get higher, causing oil to leak out a few places. Check/clean your PCV valve and/or replace it if it's questionable.
Old Jun 20, 2014 | 12:20 AM
Update: Thanks JimBlake...I decided to replace the PCV valve and that reduced the oil leak significantly. I did an engine wash to get a clean slate to see any more oil. I am now only seeing maybe 1 drop per day for a week now. At this point, I think there's not really much more benefit to try to figure out where that is coming from.
Anyhow, I want to thank you guys for the feedback.
Old Jun 20, 2014 | 09:34 AM
Oil pans tend to leak w/ age. Bolts get loose and gasket get's hard.
sixkiller
Jun 30, 2015 07:24 PM
virtual008
Feb 28, 2011 04:22 PM
Honda Accord Tuner
Feb 2, 2010 08:41 AM
Howellbl
Mar 11, 2009 06:07 AM
JohnnyFive
Apr 22, 2008 09:33 AM
