Recommendations for a 2002 Accord SE VTEC Oil Leak
Old Mar 10, 2009 | 11:08 AM
Howellbl
Question Recommendations for a 2002 Accord SE VTEC Oil Leak
I am looking at a 2002 Accord SE VTEC, fully loaded, 114,000 miles at a local dealer -- reputable, but no warranty. The price is $6500. Body and interior are perfect -- very little wear, mostly on the driver seat. However ... yes ... here it is ... an oil leak from under the engine, appears to be in the area of the autotrans bell housing or to the passenger side of the center of the engine. The cross member under the engine is wet. After a drive on the interstate, I did not notice any smoke from the exhaust, but some oil dripped from the cross member onto the exhaust pipe, where it bends under the cross member. Good maintenance records, regular oil changes, timing belt changed. I read as much as I could on VTEC oil leaks and I am afraid this is a main seal. If so, too expensive. Anyone have any recommendations before I spend a couple of hundred for a pre-buy inspection? Thanks.
Old Mar 10, 2009 | 11:26 AM
hondadude's Avatar
$200 for a 'pre-buy' inspection?? Thats unreal....find another shop.
Common oil leaks on the backside of the block are the oil pressure sending unit, and higher up the Vtec solenoid. Also the O ring at the distributor can leak and oil seeps down around the trans.
Worst case is the rear main seal HOUSING #7 in the pic below. The housing does not have a gasket, but has a sealer under it. Of course it would be a good time to replace the rear main seal as well.
http://www.hondaautomotiveparts.com/...13S841_E14.gif
Old Mar 10, 2009 | 12:04 PM
Howellbl
Thanks for the reply. Are VTEC solenoid gasket and other items you mentioned DIY items for average Accord owner/mechanic? The rear seal requires removing trans, etc, so probably beyond my talent and tools. Thanks again.
Old Mar 11, 2009 | 06:07 AM
Howellbl
FOund out the leak is at the VTEC solenoid. Another question: I know Hondas are good, but what can I expect from a car with 113K miles? THe maintenance is good, and it has been well care for. THanks.
Carta
Jan 29, 2015 06:56 PM
unt37
May 19, 2014 08:36 AM
2002rubyaccordv6
Apr 19, 2012 08:57 PM
Mott
Apr 9, 2010 07:40 AM
natesriv
Oct 31, 2007 08:44 AM
