Honda Accord 2001 P0128 ECT location?
Old Feb 24, 2015 | 07:19 PM
mg170's Avatar
Default Honda Accord 2001 P0128 ECT location?
My Engine light is on with code "P0128" on my EX -- L4 - 2.3L 2254cc type F23A4 - MFI GAS SOHC.
I went and got a temperature sensor;
Where can I change this out on my engine?
Where the red circle is I only found this;
I did an ohm test on this switch and did not read anything, dead open, no resistance at all.
If you could point me in the right direction, I would very much appreciate that. Thank you.
Attached Thumbnails Honda Accord 2001 P0128 ECT location?-ect.jpg   Honda Accord 2001 P0128 ECT location?-ect.jpg
Last edited by mg170; Feb 25, 2015 at 12:14 AM. Reason: Better picture links and more information.
Old Feb 24, 2015 | 07:37 PM
P0128 is Cooling System Malfunction. It does not necessarily mean the ECT sensor is faulty. Did you check coolant levels, radiator fan, thermostat, etc.?
Regardless, ECT sensor is under the distributor. See attached image.
Old Feb 24, 2015 | 07:44 PM
mg170's Avatar
Thank you for the quick reply, I checked the coolant levels and everything else and it is ok.
Strange thing is on my engine there is nothing attached as shown on your picture it is closed off.
I forgot to write that I did a ohm test on the switch inside red circle and it did not measure anything.
Old Feb 24, 2015 | 08:00 PM
1. The cooling fan switch is in the approximate area where you have the red circle. The fan switch is normally open (so, it should have no continuity or resistance when cold). When the coolant temperature is above 199 degrees F at that switch, then the switch contacts closes (where you would get continuity).
2. The image I previously attached shows both the gauge sender unit and the ECT sensor. Your car (a 2001) will not have the gauge sender unit; but, it will still have the ECT sensor under there. Look further underneath the distributor.
On the ’00 -02 4 cylinder Accords, the coolant temperature gauge and ECM/PCM are controlled by a single ECT (engine coolant temperature) sensor. The signal from the ECT sensor will go to the ECM/PCM; and then from the ECM/PCM to the temperature gauge for your 2001.
Previous models (98-99 4 cylinder Accords) had the gauge sender unit for the gauge, and the ECT sensor for the ECM/PCM.
Old Feb 25, 2015 | 07:28 AM
That's strange - it should be visible in that photo. Maybe the angle is wrong & you can't see further back where the sensor is.
In this picture, the sensor is #17. #14 is the gauge sender which is not present in your car (shared drawing over a few different years/models).
Attached Thumbnails Honda Accord 2001 P0128 ECT location?-2001-sulev-waterpump.jpg
Old Mar 3, 2015 | 07:07 PM
mg170's Avatar
Yes that is where it was hiding;
Now to the bad news...I changed it, disconnected the battery and connected it back up. Light did go out, but it came back on after about 2 days. I just did a oil change and they refilled the coolant therefor the fluids are correct level. Temperature of engine is below half on gauge inside the car. Not sure what else it could be.
Attached Thumbnails Honda Accord 2001 P0128 ECT location?-2015-03-03.jpg   Honda Accord 2001 P0128 ECT location?-2015-03-03-1-.jpg
Old Mar 3, 2015 | 08:01 PM
The troubleshooting for that code is pretty simple.
1. Fill the cooling system (done)
2. Turn the key to the II position, but do not start the car. Make sure the a/c is turned off. Does the radiator fan turn on?
3. Test the thermostat. I'd recommend getting the OEM thermostat from the Honda dealership. Don't go with aftermarket thermostats on Hondas.
Old Mar 12, 2015 | 04:34 PM
mg170's Avatar
Radiator fan did not turn on.
Old Mar 12, 2015 | 10:47 PM
P0128 is usually due to a faulty thermostat.
dandreye
Jun 8, 2014 04:02 PM
rao_manoj2004
Apr 14, 2013 07:30 PM
Travis Still
Jan 25, 2013 05:53 PM
geliott
Dec 18, 2012 09:56 PM
digitalreality
May 18, 2010 06:41 AM
