Honda Accord 94 Driver side windows misaligment
Old Jan 11, 2009 | 09:25 AM
kennilope's Avatar
Default Honda Accord 94 Driver side windows misaligment
Hello there. I am having a problem with my window. When it is roll up the window is not close up completely. There is a gap. I have to push it aside when closing the window. Does anybody know how to fix this problem? Also there is a rubber piece that go by the door is broken i dont know what it is call.
I would love to have my window fix because I hate the Noise when I am driving.
thank you
Old Jan 11, 2009 | 01:42 PM
finch13's Avatar
Default RE: Honda Accord 94 Driver side windows misaligment
If you take the door panel off (search for the instructions), you can reattach the switch and roll down the windows until you can see the two bolts holding the window in line up with the two holes in the door frame. Loosen them and adjust until the window rolls up the way you want it to.
Old Jan 12, 2009 | 07:17 PM
htekken's Avatar
i have this same issue, didnt know it could be fixed. will look into this.
Old Jan 12, 2009 | 11:35 PM
kennilope's Avatar
please let me know if you could fix it....
Old Jan 15, 2009 | 11:46 AM
htekken's Avatar
ORIGINAL: finch13
finch13 could you give me a better idea where the 2 bolts you are talking about are. i've taken my interior door panel of tons of time before so i know what it looks like underneath. these bolts move up/down with the glass?
Old Jan 15, 2009 | 11:51 AM
finch13's Avatar
ORIGINAL: htekken
ORIGINAL: finch13
I meant to reply to this, but I couldnt find the thread again lol.
With the door panel off, roll the window down. You should be able to see the two bolts on the bottom of the window attaching it to the window regulator (motor). Now, raise the window up until its about in the middle, there are two holes right in the middle of the inner door frame that these bolts will line up with. Theyre just big enough to put a socket and extension through.
I wish I could get a picture....
Old Jan 15, 2009 | 12:02 PM
htekken's Avatar
ok i know what you're talkin bout now. thanks a lot.
jza240sx
Apr 30, 2013 04:14 PM
slithersilver
Jun 2, 2010 10:09 PM
slithersilver
Apr 18, 2010 11:31 AM
19accord92
Apr 10, 2006 03:52 PM
