Honda Accord blows hot air on PASSENGER side,but cold air on DRIVER side
Old May 6, 2023 | 12:40 PM
sayphansenh's Avatar
Default Honda Accord blows hot air on PASSENGER side,but cold air on DRIVER side
Hello guys, I'm new here. I have a problem like the tittle, after making some research on Google, I only found the result for Blowing hot air on DRIVER side and cold air on PASSENGER side. I'm not sure should I use it to fix my car since it's not the same problem. Thank you for anyone try to help. It's 2006 Accord V6
Old May 6, 2023 | 12:50 PM
Does your car have two zones where you can set the driver and passenger side temperature?
Old May 6, 2023 | 12:52 PM
Yes sir, but even when I set it on low, It still blows hot air
Old May 6, 2023 | 02:44 PM
Most likely culprit is the driver's side air blend motor. It could also be the hvac controls, a wiring issue, or the air blend door is stuck/broken.
If you want some tests to try, I'd highly recommend purchasing the 03-06 shop manual on automanualsource.com for ~$22. It is well worth the investment for DIYers. We can help supplement any tests you'd have.
You can try the "caveman" test by hitting the motor while changing to max cool (mix motor attached and plugged in) to see if the motor moves the blend doors. You'll most likely have to pull the driver's air mix motor and move the linkage to see if it moves freely. A volt meter or test light can help identify if you have a wiring problem.
Gbrydawgs
Sep 16, 2020 03:31 PM
drugrep
Jun 3, 2013 09:32 AM
ryanw2427
Sep 19, 2012 08:39 PM
sbi
May 19, 2012 08:38 PM
bigbadbuff
Apr 17, 2012 12:56 PM
