honda accord shaking badly
Old Aug 11, 2012 | 03:53 PM
Caleb Croy's Avatar
Default honda accord shaking badly
hey i just finish putting back together my 94 ex....and when i start it it runs fine..but when in gear like reverse or any of the drives...it starts shaking badly...unless i press on the gas then the shaking seems to die down a little....now im not to positive i lined up the balance shaft belt correctly i think i might of been off just a little could this be a problem?
Old Aug 11, 2012 | 05:16 PM
doctorbee's Avatar
could be. could also be the harmonic balancer (crank pulley) find out where the vibration is coming from
Old Aug 11, 2012 | 06:23 PM
Back together? Was engine removed? If yes, check motor mount installations, particularly front and rear.
Old Aug 11, 2012 | 08:35 PM
Caleb Croy's Avatar
no the engine wasnt but i had to get the head reworked of the timing belt snapped and bent 6 valves.....the whole motor shake when i crank it up and its in park...but it gets alot worse when in reverse and drive...and on top of it all i have to replace the connecting pipe between the waterpump and thermostat housing lol...doesnt get a proper seal and whiter pours our.
Old Aug 12, 2012 | 07:16 AM
Shaking is usually engine missing. Spark plug wires hooked up wrong, loss of compression are suspects. Check engine cylinder compressions and recheck wire sequence from distributor.
Old Aug 12, 2012 | 03:12 PM
Caleb Croy's Avatar
ok i checked compression and its 150 on 1 and 3...and like 145 or 148 on 2 and 4...i say 145 or 148 becaus it was the notch right before 150....could u possible post a pic of the way the plugs are ran? because i tried to go by what i thought the book showed and it woulrdnt start at all..so then i looked at a pic online and seen it ran a different way and tried that...so now it cranks but shakes under load
Old Aug 12, 2012 | 09:19 PM
See following link w/ diagram.
Honda Acura ignition (no spark) troubleshooting tutorial - How to
The #1 spark plug tower is identified w/ A1 or A near the tower. Firing order 1-3-4-2 going CW around distributor cap.
Old Aug 13, 2012 | 11:18 AM
Caleb Croy's Avatar
thanks for the link that info is alot better than anything i could find and what was in the book
Old Aug 13, 2012 | 11:43 AM
doctorbee's Avatar
make sure the timing belt isn't off by a couple teeth too.
there's also a balancer belt you have to worry about
Old Aug 13, 2012 | 01:47 PM
Caleb Croy's Avatar
timing dead on but the balancer belt is off by a little...trying to line it back up right now...but having trouble since it keeps moving lol
