Honda Accord shuts off
Old Sep 16, 2015 | 09:32 PM
Jr_559's Avatar
Default Honda Accord shuts off
Hey I have a 1991 Honda Accord and it shuts off on its own, about 2 weeks ago it used to turn off at stop signs and stop lights and once on the free way. I changed the alternator and cleaned fuel injection,(alternator had stopped working) after that it stopped turning off . Recently I was driving through a parking lot and it shut off 8 times while I was trying to get out, and when I finally made it out it didn't turn off until the next day I entered another parking lot. It only shuts off in parking lots now. not sure what the problem is.. Help !
Old Sep 16, 2015 | 09:36 PM
Does the engine stall when you shake the key?
Old Sep 16, 2015 | 09:53 PM
Jr_559's Avatar
No it doesn't
Jr_559's Avatar
It stalls when I move the steering wheel side to side
Old Sep 17, 2015 | 10:24 AM
When engine shuts down do all gauge panel lights stay off or come on? If they stay off you are likely losing power to the ignition and perhaps fuel pump also.
Old Sep 17, 2015 | 02:14 PM
Jr_559's Avatar
They all come on
Old Sep 17, 2015 | 03:07 PM
travrach's Avatar
The PGM-FI Main Relay is a common issue outside of the ignition switches.
Old Sep 17, 2015 | 03:20 PM
Turn keyswitch to On in quiet conditions and listen carefully for fuel pump (in fuel tank) to come on, run for ~3 secs, and go off. If you can hear this every time, the problem may not be main fuel relay (MFR).
If you don't hear fuel pump (and no start conditon exists), then MFR is likely, although a sticking fuel pump can't be ruled out w/o further testing.
A sticking fuel pump can sometimes be "revived" by hammering w/ repeated on/off/on/off... of the keyswitch.
When car cuts off, does it immediately restart or you have to wait some time? If yes, MFR is lkely.
Additional info on MFR:
http://techauto.tripod.com/
Old Sep 17, 2015 | 05:36 PM
Jr_559's Avatar
When it shuts off it turns back on like nothing happened, it hasn't turned off yet it stops for a couple days then it happens out of no where
Old Sep 17, 2015 | 06:45 PM
It will be difficult to determine the fault since it is very intermittent.
Tests conducted when fault is absent don't do anything
