Honda SL3 Bypass module
Old Jan 9, 2017 | 05:40 PM
tony209's Avatar
Default Honda SL3 Bypass module
There is a Blue wire names, "While Running". What is it? and how it works? Please let me know.
Thank you very much in advance,
Tony
Old Jan 9, 2017 | 06:40 PM
  1. What year and model car is this for?
  2. Are you using the SL3 Module with a remote starter, remote alarm or combo?
Old Jan 10, 2017 | 09:08 AM
tony209's Avatar
Thank you very much for the reply!
I have 2009 Accord, LXP. I purchased a SL3 package with the factory remote key starter, push three times to start the car. But, my vehicle already has the Autopage Alarm in it. There is also a "While running wire" is built in. So, my question is, what does that wire actually do on the SL3 and would it work if I don't connect it to any where. Would you tell me what it does in the circuit here? Thank you.
Old Jan 10, 2017 | 01:53 PM
The Toecutter's Avatar
You do realise that below in this thread there are "related topics" and 1 of them partly addresses the SL3 circuits and package. It might be worth having a look.
Old Jan 10, 2017 | 08:00 PM
1. The Honda add-on accessory remote starter kit (https://www.handa-accessories.com/ac...emotestart.pdf) does not require a SL3 bypass (for the Immobilizer). This is probably not what you're referring to; but, I am including it for the sake of comparative info.
2. It sounds like you purchased a SL3 bypass module with an aftermarket add-on remote starter, that can use the factory remotes (like this? Add-on Remote Start for Honda & Acura - Use Factory Remotes for Remote Start). -- Is that correct?
As quoted from their web-page: "One important note about using 'add-on' remote starts in Hondas: The factory remote controls in your Honda do not work when the car is running - that's the way Honda engineered the car. This means that if you're using a remote start that works from your OEM remotes, you'll be able to start the car just fine, but you will NOT be able to unlock the doors with the factory remote control. The only work-around is to use a remote start that comes with its' own remotes. Since aftermarket remotes do not rely on the factory keyless receiver, they will work when the car is running."
3. On the SL3 Module, the (-) negative ground while running blue wire is to be connected to the aftermarket remote starter system "status output" wire.
When the SL3 Bypass Module gets a ground signal from that wire, it activates. It is only a brief ground signal, not constant ground. The SL3 Bypass will then temporarily override your vehicle's antitheft key only when the remote start is activated.
keep_hope_alive
Dec 19, 2024 04:07 PM
gary85_
Jan 29, 2015 05:55 PM
val
Jan 21, 2013 12:33 PM
shan5
May 18, 2011 09:36 AM
fd1836
Mar 22, 2010 01:38 AM
