Sponsored by:
Sponsored by:
Honda wont Start
Old 02-12-2011, 06:04 PM
Americadian's Avatar
Default Honda wont Start
Hey guys this problem is when i push the clutch in i get power and here a click but the car will not turn over..... the thing is sometimes it will start than sometimes it wont...... what could it be driving me Nuts. and i can also push start it...... could it be my battery? the car is a 95 honda accord lx 2 door
Old 02-12-2011, 06:35 PM
Welcome newbie!
I'll move this over to General Tech where it belongs.
Check both ends of both battery cables. Loose/dirty/corroded? When you try & it doesn't crank, check the voltage at the 2 hot wires at the starter. If either one doesn't have battery voltage, tell us which one.
You can also check the clutch switch. Sometimes it gets pushed out of proper position, or broken, or ???
Old 02-12-2011, 06:46 PM
If the click is coming from the starter, it sounds like the contacts for the solenoid are worn out.
If you hold the key in the start position, have someone hit the starter with the handle of a screwdriver with light/medium force. If the car starts, you pretty much verified the problem.
Tony1M
11-06-2023 08:29 PM
jimmy3fingers
10-04-2013 08:02 PM
gasface11
07-11-2012 12:33 PM
MrGmo
09-28-2007 01:40 AM
HustlinOwl
09-15-2006 03:20 AM
Quick Reply: Honda wont Start
