Horn honking randomly!?!?! Pretty much brand new car!
Old Feb 22, 2014 | 04:10 AM
vato12345's Avatar
Exclamation Horn honking randomly!?!?! Pretty much brand new car!
Hey guys so I have a 2013 Honda Accord Coupe LX which is about 6 months old and it just recently started honking randomly while I'm driving. There is no pattern to it at all. The only aftermarket thing I have done to it is installing "LED GLOW" interior lights, but that has been installed for about 5 months so I don't know why it would start acting up now. If anyone has any advise I would appreciate it. Thanks!
Old Feb 22, 2014 | 09:11 AM
It could be a faulty horn relay (under hood fuse box), faulty horn switch (steering column), or damage cable reel in steering wheel (internal short to ground).
There is also a part called "control box" in the circuit diagram which is unexplained, perhaps part of security system interface.
You will need a shop manual to perform diagnostics, if you intend to diy. Check automanualsource.com for an inexpensive download manual.
Old Feb 22, 2014 | 09:25 AM
The cable-reel sub-harness will probably have to be replaced. There was a Honda service bulletin 13-029. I already seen this on some other 2013 Accords.
The following is part of the service bulletin:
Horn Sounds By Itself; Driver’s Airbag Rattles
SYMPTOM
The horn sounds by itself, or there is a rattle coming
from the driver’s airbag.
POSSIBLE CAUSES
There are three possible causes. The cable reel
harness is not routed correctly, the horn harness has
shorted against the SRS module retainer, or the airbag
module is not centered.
VEHICLES AFFECTED
2013 Accord 2dr L4 - From VIN
1HGCT1...DA000001thru 1HGCT1...DA012544
2013 Accord 2dr V6 - From VIN
1HGCT2...DA000001thru 1HGCT2...DA006749
2013 Accord 4dr L4 - From VIN
1HGCR2...DA000001thru 1HGCR2...DA131690
2013 Accord 4dr V6 - From VIN
1HGCR3...DA000001thru 1HGCR3...DA027860
2013 Crosstour 2wd L4 - From VIN
5J6TF3...DL000001 thru 5J6TF3...DL002700
2013 Crosstour 2wd V6 - From VIN
5J6TF1...DL000001 thru 5J6TF1...DL001599
2013 Crosstour 4wd V6 - From VIN
5J6TF2...DL000001 thru 5J6TF2...DL002887
CORRECTIVE ACTION
Replace and properly route the cable reel sub-harness;
make sure that the airbag module is centered.
PARTS INFORMATION
NOTE: To help clarify where new parts are used in the
REPAIR PROCEDURE, the new part is listed in the
applicable repair step with a “>” symbol.
Cable Reel Sub-wire: P/N 77901-T2A-Y10
Torx Bolt (two required): P/N 90134-S6A-A80
Old Feb 22, 2014 | 06:58 PM
Warranty???
Old Feb 22, 2014 | 07:02 PM
It is covered under the normal warranty. Many dealerships won't have that sub-harness in stock and will have to order it; but, it is quick.
Old Feb 23, 2014 | 12:32 AM
vato12345's Avatar
Thanks for the advice guys. And ya I just wanted to see if there was a quick fix that I could do on my own before I brought it in to the dealer because they would charge $115 to diagnose which I think is pretty stupid.
Old Feb 24, 2014 | 09:35 AM
Wow, they charge a diagnosis fee for warranty work?
Tenoke
Mar 11, 2014 01:55 AM
Rtherres
Jan 23, 2012 12:23 AM
TimeBombTown
Jun 26, 2009 09:37 AM
pham9006
Apr 8, 2009 11:37 AM
Fast Foward Racing
Jan 29, 2008 06:51 PM
