horrible problem
Old Jul 22, 2008 | 01:40 PM
tbird07
Default horrible problem
I have a 1994 Honda Accord Ex it is throwing a crankshaft position sensor code but from what i understand it is in the distributor so i replaced the distributor and it is still throwing the same code but the car also wont rev above 3500 rpms and i just can't figure out why and i dont know how to fix it does anyone no what the problem could be
Old Jul 22, 2008 | 02:55 PM
Default RE: horrible problem
Did yourule outwiring problems (loose/dirty/corroded plugs) first?
Old Jul 23, 2008 | 12:08 PM
tbird07
yea i have ruled out wiring problems i honestly think but i dont know maybe computer problem or it jumped time
Old Jul 23, 2008 | 02:16 PM
Yeah, check cam timing - thats not too hard to rule it out.
ECU is generally pretty robust so I tend to think of other stuff first.
Old Jul 24, 2008 | 03:38 PM
tbird07
what would cause the car to throw a CKP code
Old Jul 24, 2008 | 03:41 PM
falkore24's Avatar
Is the check engine light flashing? Limp-home mode >3500 rpm limit
Old Jul 25, 2008 | 01:23 PM
brayner's Avatar
have you checked the obvious? the crank position sensor? If it's unplugged the engine will not start. it may be damaged or have excessive debris on/arounf it
Old Jul 25, 2008 | 07:18 PM
tbird07
yes i checked the sensor and it is plugged in and when it is started the check engine light doesn't blink
Old Jul 26, 2008 | 08:45 AM
There are several crankshaft position sensor errors. What specific error code do you get from the ECU.
Old Jul 28, 2008 | 08:07 AM
1994 is OBD-1 so I think theres only one CKP code (4).
