How Can I "Jump" Power WIndow Connector To Test Window Motor?
Old Apr 30, 2012 | 04:33 PM
Hey Redbull-1, how have you been. I'll send a PM later with more fun I'm having.
Hi poorman212, I am much better. We'll talk in PM later.
Sorry, jkeely for the off-topic conservation with my friend.
Old Apr 30, 2012 | 06:53 PM
Originally Posted by jkeely
Just so I don't send everything up in flames. I short both of those sets of wires -I connect GRN/WHT to RED/YEL and connect BLK to RED/BLU at the same time to make the window go UP?
Yes, at the same time. You are sending power (from the GRN/WHT) to the motor and ground (from the BLK) to the motor by doing these two "jumps" at the same time.....Key On of course.
And, I too am sorry for the "off topic" conversation......got to keep up with friends
Old May 2, 2012 | 03:15 PM
jkeely's Avatar
Default Window
Poorman,
Connected as you suggested; grn/wht to red/yellow and blk to red/blue but, window rolled DOWN.
Any other ideas?
Thanks!
John
Old May 2, 2012 | 03:22 PM
Refer to the link in post #6 of this thread to try to see if the motor will make the window go up.
Here's a video to remove door panel:
How To Install Replace Door Panel Trim Honda Accord 94-97 Front 1AAuto.com - YouTube
Old May 2, 2012 | 03:28 PM
jkeely's Avatar
Default Appreciate it.
Thanks Redbull. I actually don't have to pull the door cover off as the switch unit pops out. I do appreciate the vid though.
By the way you and Poorman "off topic" your brains out here. It is not a problem.
Old May 2, 2012 | 03:48 PM
The other connector is to test the motor directly, which generally requires removing the door panel.
basket_case
May 10, 2015 06:06 PM
scratch
Feb 15, 2012 06:41 PM
93hondaccord
Oct 13, 2011 09:24 PM
HondaAficionado
Nov 30, 2010 05:24 PM
Wicked Pete
May 18, 2010 06:25 PM
