how to change air cleaner element on '05 accord
Old May 4, 2008 | 06:43 PM
ebeighe
Default how to change air cleaner element on '05 accord
On my old accord ('94) this was a trivial job, but...
I removed the four screws but couldn't lift the housing out of the way enough to get the old filter out.
The owner's manual doesn't say anything about it in the DIY section, so I'm guessing that means they are hinting you should take it to the dealer.?
What's the procedure?
Old May 4, 2008 | 07:42 PM
RTexasF's Avatar
Super Member
Default RE: how to change air cleaner element on '05 accord
Four or six cylinder?If 4 cylinderremove the largehose to the throttle body then pull up on the airbox cover. For a six:
http://www.driveaccord.net/forums/showthread.php?t=8089
Old May 4, 2008 | 10:22 PM
ebeighe
ORIGINAL: RTexasF
Whoops, sorry -- should have said it is a 4 cylinder. Those are great pictures of the 6 cylinder -- looks like those folks have it easy :-)
I wondered about the large hose -- it is held tight to the airbox by this weird thing that looks like a spring (rather than, say, a clamp that could be loosened). Am I correct in thinking i need to just pry that springy thing out of the way so i can loosen the hose?
Old May 4, 2008 | 10:32 PM
On my 2003 that spring thing just gives a little extra grip to the big rubber duct. You can pull that big duct off without bothering to do anything to the spring.
But on my 2003, it's a lot easier to work that thing if you disconnect a couple little vent tubes to allow more motion. It DOES seem like the fender mounting flange is just in the way by a fraction of an inch. I bet someone wasn't paying attention to that little stuff when designing the car.
jcyp20
Jul 9, 2009 07:17 PM
status
Feb 21, 2008 09:39 AM
musto
Jun 4, 2007 09:49 AM
roozoo
Jul 1, 2006 03:34 PM
roozoo
Jul 1, 2006 03:33 PM
