how to compress TB tensioner
Old Dec 3, 2011 | 03:54 PM
thewhitegorilla's Avatar
Default how to compress TB tensioner
I have a 2000 honda accord lx with the 3.0 v6 I have the belt tight with all the slack to the tensioner side and all the marks lined up but I need to install the tensioner, it is a small cylinder with a boot on it and has a hex on the end. I tried once to turn this hex but it did not move. I did not want to break it, or get the adjustment wrong. If can get this thing colapsed and installed I wil be able to finnish it the rest of the way w/o problems. Any help is appreciated
Charles
Old Dec 3, 2011 | 05:34 PM
Small C-Clamp and a piece of wire.....C-clamp to compress, the wire will "lock" it in place..
Old Dec 3, 2011 | 07:28 PM
thanks for the response, but actually there is an 8mm bolt at the end of it, you take that out with it pointing up and there is a slotted screw inside turn that whilst applying pressure to the bellows end of it and then hold it firm with a tyrap. It should be noted that the slack must be worked to the tensioner side of the engine, by backing the camshafts/crank up meshing with the cog in the belt that you need to make tight then reposition to your marks. I used small pieces of wire wrapped through the pulleys to keep the belt cogs engaged while doing this.
Charles
bmdavis
DIY Answers.
Feb 14, 2024 11:32 AM
Jaymo
Sep 12, 2009 05:28 PM
TACORICAN
Jun 11, 2007 07:44 PM
DrakeRake
Jul 15, 2006 08:50 PM
vdabis
May 2, 2006 02:42 AM
