How do I turn off CEL
Old May 10, 2007 | 09:17 PM
Alien VFR's Avatar
Default How do I turn off CEL
2002 Accord EX.
Check engine light is on. Not sure why, I will check it out.
What's the technique for turning it off?
Old May 10, 2007 | 11:37 PM
00AccordLX5spd's Avatar
Registered User
Default RE: How do I turn off CEL
First of all, find out why check engine light is on. Go to AutoZone & have them read the code with their scan tool. The data link connector is located under the instrument panel on the driver's side.
Does anything seemabnormal when you are driving?If not, did you screw thegas cap on till it clicked 3 times last time you filled up? That will cause the CEL to come on (it happened to me and I was like WTF?)
After the problem has been resolved, remove the # 13 fuse (located in passenger side fuse/relay panel)for 10 secondsto clear the codes.
Old May 11, 2007 | 03:01 PM
Alien VFR's Avatar
I started the car with the fuel cap off and drove it 50 feet. Not sure if that's the problem. The car operates fine. I will have it checked out though.
Isn't there a way to turn it off by holding the trip meter button or something? ThoughtI heard that somewhere...
Old May 11, 2007 | 03:54 PM
sir_nasty's Avatar
that trip meter "trick" is for resetting your Maintenence required light, if the car seems/feels fine I would probably tighten down the gas cap then reset the light and see if it comes back, if it does get the code read.... This isn't the best way to go about things but it is the easiest.... Ideally you should have the codes read to find out for sure what's wrong
Old May 11, 2007 | 11:46 PM
Registered User
Nasty is right. The odometer trip button trick is only for the "mainenance required" light - different form CEL. If you know the security code to your radio, you can simply disconnect the negative battery cable and leave it disconnected for about five minutes, hook it back up and the lightshould be reset. That is how I reset mine, but mine is a 2000 LX and doesn't require a security code in radio.
Old May 7, 2010 | 10:27 PM
01Accord01's Avatar
how do you do the "Odometer Trick" because my Main't Req'd light is on but its not for anything serious just the regular required main't.
Old May 8, 2010 | 10:09 PM
Maintenance required lamp is simply triggered by mileage - it's a reminder to change your oil.
1) Key OFF.
2) Press & hold the odometer reset button.
3) Continue to hold the button while turning the key ON (don't need to actually start the engine).
4) Continue to hold the odometer reset button forever - well, maybe about 20 seconds.
5) The Maint.Req. lamp will flash a few times then stay off.
DONE.
Old May 9, 2010 | 12:41 PM
01Accord01's Avatar
thanks i appreciate it
19dabeast85
Mar 20, 2012 11:26 PM
thegeneral71
Jun 11, 2011 06:51 AM
SolEX01
Aug 10, 2010 05:04 PM
Grav1sT
May 7, 2008 05:40 PM
