Is 325 for CAT install, gaurenteed to turn off CEL, worthy?
Old May 7, 2008 | 01:02 PM
Grav1sT
Default Is 325 for CAT install, gaurenteed to turn off CEL, worthy?
Mechanics are 100% it is the CAT, responses appreciated.
Old May 7, 2008 | 01:21 PM
Default RE: Is 325 for CAT install, gaurenteed to turn off CEL, worthy?
That sounds like a real good price for a new cat, installed. It's evenan OK price for the cat-converter, NOT installed.
If theyWARRANTY it to fix the CEL, go for it. If it turns out NOT to fix the CEL, they have to keep working for free to turn off the CEL, right?
Old May 7, 2008 | 01:27 PM
00AccordLX5spd's Avatar
Registered User
We still need to know what the CEL code is if we are going to help you. I thought your mechanic said it was"carbon buildup underthe plenum" and was ready to charge you $400 to fix that? Why did he change his mind all of a sudden?
If you want help, post the CEL codein the other thread. If you want to throw away money, pay your mechanic to replace a bunch of parts and hope the CEL goes off. it's your choice
$325 is a terrible price if there is nothing wrong with the cat in the first place
Old May 7, 2008 | 01:30 PM
Grav1sT
yep theyll keep workin till its off, i hope his word is good.
Old May 7, 2008 | 01:33 PM
falkore24's Avatar
It might be a sensor that costs them $5. After they charge you $325 for a cat, they may just fix what the actual problem is. If you trust them, go for it, but that price seems too low for a cat, install and guarantee ..... but then again, I don't trust mechanics.
Old May 7, 2008 | 01:43 PM
Grav1sT
mechanic said it was the CAT im not sure what codes, but i am going to ask to see what he did when i go pick it up... how hard is it to do the CAT by myself?
Old May 7, 2008 | 02:10 PM
In theory it's not too hard, just bolts & gaskets. But it's always hot, rusty, dirty. If they use salt on the roads in winter, you'll spend awhile under the car cursing at things while you break off the bolts.
Old May 7, 2008 | 03:49 PM
Registered User
ORIGINAL: JimBlake
...and lose a good amount of blood from your knuckles[:@]
Old May 7, 2008 | 05:40 PM
deserthonda's Avatar
it all depends what the code is and if there is only 1 code ,,,,,,
by the way please input year and model in your signature
thanks
Alien VFR
May 9, 2010 12:41 PM
Willb2305
Oct 27, 2009 07:37 PM
Willb2305
Oct 27, 2009 07:36 PM
sir_nasty
Mar 10, 2006 04:25 PM
