Cat or No Cat that is the question
Old Mar 2, 2006 | 02:27 PM
sir_nasty's Avatar
Default Cat or No Cat that is the question
So eventually (hopefully next month...) I want to put on a set of DC Headers and a cat back exhaust.... However, I was wondering what peoples opinions are on wether or not to keep my Catalitic Converter in. I'm thinking remove it and fab a piece to connect the headers to the cat back exhaust... any opinions or suggestions?
Old Mar 3, 2006 | 02:07 PM
cowboy45's Avatar
Default RE: Cat or No Cat that is the question
Well, the noise level from the car will be a bit louder, so depending on what exhaust you buy, think about putting the silencer in if it's not already. Also your state has its E-Check and without the cat, your car will not pass. So if you have to take that anytime soon I would say no. It's not really going to make that much of a difference and might end up just giving you a headache.
Old Mar 3, 2006 | 04:56 PM
sir_nasty's Avatar
Montana has no E-Check so that's not an issue... I was wondering if the gains coupled with a Header and cat-back exhaust were worth removing it....
Old Mar 3, 2006 | 04:57 PM
sleep depervation's Avatar
you could also buy a high flo cat.
there are some made that will even pass some state inspections, and if they just look under the car it looks like you have one.
Old Mar 3, 2006 | 06:30 PM
sir_nasty's Avatar
does anyone know what advantage I would have to getting a high flow cat vs. no cat at all?
Old Mar 3, 2006 | 08:28 PM
marbro's Avatar
advantages with a cat, less tickets get a good highflow cat thats all you really need to do.... but without a cat you get a little bit of a of increase from the crank to wheel hp but not enough to justify the potential tickets and the fact that you can smell that you dont have a cat on
Old Mar 10, 2006 | 04:25 PM
projectaccord96's Avatar
Ever heard of a check engine light due to there being an 02 sensor after the cat? My camry didn't have a cat,it does put off a strong exhaust sound
benzilla69
Jun 28, 2010 12:56 PM
lancing
Sep 6, 2008 02:45 PM
streetcustoms
Oct 25, 2007 05:20 PM
blackex19
Aug 22, 2007 02:37 PM
pyaarawala
Jun 1, 2007 01:19 PM
