how do you recycle used auto fluids
Old Sep 18, 2008 | 09:46 PM
faosh's Avatar
Default how do you recycle used auto fluids
Its easy to recycle used motor oil. Not quite so with transmission fluids, brake fluids, and power steering fluids. The auto parts store don't take them back. To those of you who are not mechanics, how do you recycle them?
Honda dealerships typically take them back provided we take the fluids back in the same container as it was sold. So I am forced to buy fluids from them, just so that I can recycle them back.
Old Sep 19, 2008 | 08:29 AM
falkore24's Avatar
Default RE: how do you recycle used auto fluids
all the fluids mentioned are oils ..... Strauss near me throws them in with the recycled oil. Especially tranny fluid ..... that's the same thing as motor oil with a few additives and red dye.
Old Sep 19, 2008 | 08:34 AM
I agree. I mix trans fluid and I save old brake fluid for use as a cleaner on brake parts (no solvents are recommended).
Old Sep 19, 2008 | 08:46 AM
falkore24's Avatar
^^^ I use brake cleaner!!! That stuff cleans anything!!!! ..... and it cools parts quick, fast and in a hurry!!!!
Old Sep 20, 2008 | 10:05 PM
faosh's Avatar
How about antifreeze? Its not oil and is poison. How do you recycle coolant?
Old Sep 21, 2008 | 05:59 AM
This is not federally regulated. Each state has their own set of impractical guidelines. No easy solution here that I know of.
Old Sep 21, 2008 | 05:36 PM
falkore24's Avatar
ORIGINAL: faosh
The Strauss Auto near my house has a separate container for it.
Old Sep 21, 2008 | 06:35 PM
I know my local Autozone takes oil and maybe coolant for free
Old Sep 21, 2008 | 10:50 PM
Check your local sewage-treatment department. Anti-freeze is sometimes OK to pour down the drain. It's a heavy alcohol, and itis bio-degradable. Its not particularly healthy for home septic systems; it can disrupt the little critters in your septic tank.
Old Sep 22, 2008 | 08:12 AM
falkore24's Avatar
Antifreeze is usually ethylene glycol; the green stuff anyway. It is poisonous, so I doubt that anyone wants it in their groundwater via leaky sewage pipes. Amsoil uses propylene glycol which is safe, but I doubt the sewage authorities recognize the different fluids.
MessAround
Jun 19, 2011 07:34 PM
mklovell
Jan 23, 2011 01:27 PM
t3baird
Mar 19, 2008 09:38 PM
Mrheat
Nov 13, 2007 05:45 PM
accordfan
Apr 21, 2007 06:02 AM
